-   -   Confusion over cam timing tables, am I mixed up? (http://forums.pelicanparts.com/porsche-911-technical-forum/210365-confusion-over-cam-timing-tables-am-i-mixed-up.html)
H.G.P. 03-10-2005 06:55 PM
Stamped on each of my camshafts are the "dot" stamped on the top (when at TDC), and in this same orientation on the bottom of each is stamped "05"
I'm not sure if I did the correct dial reading, as I used the reading page 207 in Waynes book for 69 911E, but in the Haynes there is a refererence to a 901/05 as "engine" for dial gauge reading.
:confused:
camgrinder 03-10-2005 07:10 PM
The 05 cam is the E profile.
Should be set at 3.0 to 3.3 mm.
H.G.P. 03-10-2005 07:22 PM
"camgrinder The 05 cam is the E profile.
Should be set at 3.0 to 3.3 mm. "
Whew...thanks!!
