Anyone use that Wurth's Satin Black Trim paint
I bought the paint mentioned above and noticed in the instructions that it does not say anything about primer, just clean metal and shoot.
Has anyone used this stuff? I can't imagine it will work good without primer. Hopefully I am wrong.
Old 03-11-2005, 11:52 AM
If the surface is prepped properly then you don't need primer. Shoot light even coats.
Warren & Ron, may you rest in Peace.
Old 03-11-2005, 11:55 AM
Eric Coffey's Avatar
What are you painting? If it is a previously painted surface (that is still adheared well), you cab usually get away with just roughing up the surface (maroon scotch-brite), and cleaning/degreasing. If you are painting bare metal, you should use a self-etching primer as a base coat (find it in black if using Wurth satin black). Even if you are not painting bare metal, the use of a primer (2-3 sanded coats) will help hide any imperfections. It will also save you from building up a bunch of color coats to get max coverage (saving you paint).
Old 03-11-2005, 12:24 PM
Does the painted trim on a 911 have primer under it?
Old 03-11-2005, 12:25 PM
I bought it for all the trim. When you say rough up, do you mean with like 80 grit sand paper?
Thanks.
Old 03-11-2005, 12:42 PM
Oh, I don't think it had primer under it.
I don't think I've see trim with primer either.
...and NO don't rough up with (very course) 80 grit. You want a Very Fine grit sandpaper or perhaps a fine scotch brite pad to barely scuff the CLEANED surface...as mentioned by Eric.
Old 03-11-2005, 01:16 PM
scottb's Avatar
Green Scotchbrite pads work great for scuffing work before painting. If it's got a good coat of paint on it now, then you don't need to prime. If not, then prime first (a light coat is all you need), and then follow-up with several thin coats of the Wurth.
1984 Targa
Old 03-11-2005, 03:47 PM
anthony's Avatar
What painted trim??? If you mean the black trim like around the windows and on the door handles, then you are looking at a black annodized coating.
-Anthony Siino
1981 911SC
1974 914 2.0L
Old 03-11-2005, 04:00 PM
The prior owner of my car had tried to backdate it to an earlier model (it's a 73, but he had painted my engine grille and turn signal surrounds siliver). I stripped the paint off the grille and scuffed it up with a 3M pad and then applied 5 thin coats of the Wurth Satin trim paint. It goes on very smoothly and covers well (it's not the same color as the original anodizing but I think it looks better than the silver). I think that if the surface has some grip, it should stay. Good luck.
Joe
Edit: It's been on for about a year and half and still looks like the day I applied it.
Old 03-11-2005, 04:08 PM
