LinkBack | Thread Tools | Rate Thread |
Engine project continues....exhaust system to be installed this weekend
Fun and games continue...replacing the clutch turned into much more...pages and pages of invoices...
John |
I have a question, or two...
Did you paint the headers with high temp paint or regular paint? I assume that regular paint will just flake off after being heated to those high engine temps a couple of times. And secondly: Is there any other reason besides looks as to why you would want to paint the headers? What else do you have planned?
1976 911 S Targa 3.2 |
It is high temp paint, the headers came black, but the paint was junk so I stripped them and repainted with that paint to help protect them. I do not drive the car unless it is clear and warm so I don't have a lot of weather touching them...it should work. I was going to pain them black like they came, but when I was picking out the paint I went with red...matches the car...
John |
To answer your other question...as I stated, I originally removed the engine to replace the clutch that was slipping and shuttering. I have also...
New Bursch muffler All new exhaust gaskets Air box sensor plate housing gasket Thermo time switch replacement Oil pressure sending unit replacement Headers (from eBay, good price!) New oil lines to back date exhaust to a '74 muffler Pertronix Ignitor Intake manifold gaskets Lower valve cover gaskets Upper valve cover gaskets Valve adjustment New brake pads Oil hoses O-rings for the oil cooler New steering wheel Crank shaft to flywheel seal New ignition high performance ignition wires Nothing to crazy, but a lot of little things that will hopefully make the car run better and not leak anymore....
John |
John,
If you need any assistance, I am only a hop, skip, and a jump away from you.
'99 996~LSD~VE Wheels~H&R Cup Kit~Aero~Recaro~X51~M&K~GT3 Roll Bar '77 911 ~ very modern running gear ~ Gruppe B...the Midwest motorsports playground |
thanks JST...do you know where in my general area I can get my flywheel resurfaced?
John |
More pics....muffler coated and ready
John |
Cool. I like the red headers.
You getting her out for a test run this weekend, too? The weather is supposed to suck. Man, I have all these new parts on mine and I can't go out and play!
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
My goal is to be ready on April 1st....I can't stand this weather...reapinted all of the sheet metal and need to get all that back on as well as clean out the trans housing beofre I put her back together...
John |
