twobone's Avatar
How hard will it be to re-paint the targa bar?
PO had painted my 81' SC Targa Bar to match the body. Its a metallic BMW Blue.
I don't mind the body colour, but I'd like to go back to a black Targa bar.
Will a body shop have to remove my rear glass and all of the hard ware?
Should they sand off all of the old paint?
Lastly......how is the Targa script attached? Will they need to remove it?
Old 03-11-2005, 06:39 PM
Virginia Rocks!
VaSteve's Avatar
Some people can pull of the Targa script with dental floss. If it's mounted with pegs, but a new one to figure out whee the existing pegs would be and drill it out.
I'm going to paint mine in place if I ever get to it. I will do a lot of masking first.
Rosewood 1983 911 SC Targa | Black 1990 944 S2 | White 1980 BMW R65 | Past: Crystal 1986 944 na
Guards Red is for the Unoriginal
Old 03-11-2005, 06:47 PM
ausdilecce's Avatar
To prep and paint the targa bar properly, you need to remove the bar itself..
The bar is simply an alu skin that covers the actual metal of the roll over hoop.. It comes off rather easily -- read this for a howto Removing the targa bar?
The targa script can be either double sided taped on or secured with pegs and 'nuts'. You will see what I mean by pegs and nuts from the thread above..
Once the bar is off, the paint shop will know what to do to prep and paint. The original color *and texture* is on that thread as well IIRC
Good luck
1987 ROW Carrera Targa, SW chipped
1983 U.S.A. SC coupe ( bro has her now )
Old 03-11-2005, 06:55 PM
Zeke's Avatar
I think the bar is stainless steel. The one on my '77 was. I sanded and primed it with XIM and painted it with Rustoleum Satin Black. Both in spray cans. With the proper preparation, primer and a little patience, your job will look as good as new. On or off the car. It lasted for years.
Old 03-11-2005, 07:10 PM
ausdilecce's Avatar
Zeke,
You are probably right. When I took mine off, it was so light that I thought it had to be Alu, but alu is simply too soft in that thickness..
Old 03-11-2005, 07:13 PM
Zeke's Avatar
Either way, AL or SS, it requires a better primer than what you would use on the body, IMO.
Old 03-11-2005, 07:37 PM
ianc's Avatar
It was my original impression that the bar was Al was well, but the fellow who did the powder coating told me that it was in fact SS when I got it back...
ianc
BMW 135i. Nice. Fast. But no 911...
"I will tell you there is a big difference between driving money and driving blood, sweat and tears." - PorscheGuy79
Old 03-11-2005, 10:59 PM
