Looking for standard O-ring size - Weber carbs
I found one of the O-rings for the idle jet holder on my Weber carbs was damaged - they're 40 IDA3c's - does anyone have the standard (ie English) dimensions for these so I can find them locally?
Thanks Jim |
You do not have permissi
Sorry, can't help at the moment but can say I previously tried to rebuild my Weber carbs with an unknown aftermarket universal rebuild kit "performance products something"? (which was not from Pelican nor PMO) and EVERY o-ring was the wrong size.
Meanwhile other things are still happening. |
I ended up taking the old o-rings out and driving 25 miles each way to the nearest (competant) metric-parts dealer. This was in the Bay Area.
I would rather be driving
I went to the local hardware store and got some that were indistinguishable from the proper ones. Buy a few extra they are only pennies.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
