-   -   Does it look too low ??? (http://forums.pelicanparts.com/porsche-911-technical-forum/210948-does-look-too-low.html)
stv951 03-14-2005 12:46 PM
I know its not a way to tell just by looking, but you have to measure to check, but does it look too low ? I get some rubbing at the front (7x16 with 205s) no problems back with 9x16 and 245shttp://forums.pelicanparts.com/uploa...1110833148.jpg
jyl 03-14-2005 12:48 PM
Looks nice. As long as the rubbing and driveways are okay, I say you can't be too low. Maybe you can increase front camber to reduce rubbing?
Glasgow 911SC 03-14-2005 12:51 PM
As far as looks go, that's :cool: I get rubbing at the front inside. Maybe you should think about fitting a plate similar to Mikes (89911).
http://forums.pelicanparts.com/uploa...1072017163.jpg
stv951 03-14-2005 12:53 PM
I am considering dialing more negative camber up front, but was told that I would lose some high speed stability. Car becomes nervous (so they say). Is that true ?
I will also roll the fender lips.
If I increase negative camber I will get more oversteer, right? Car was very nervous and oversteered alot on a track day yesterday. Will that make things worse ?
stv951 03-14-2005 12:55 PM
sorry Chris? What is that plate ?
Glasgow 911SC 03-14-2005 01:03 PM
That's the area my front tyre rubs at. My car is quite low at the front too. Mike fitted a small, sheet metal plate there to stop paint damage at full lock.
kqw 03-14-2005 01:08 PM
I am assuming that you are rubbing at the front fender lip?
Have you rolled the fenders?
stv951 03-14-2005 01:11 PM
Yes they rub on the lips. Not rolled them yet. It also rubs inside when the steering turns (to make a U-turn etc.)
john70t 03-14-2005 01:32 PM
The first question I ask when hearing the "rubbing" issue is why not start with ride-height and/or better yet new front shocks?
Mabye hit the apex a little less perpendicular, or become a better driver?
It seems kinda funny to take an OEM car and glue/weld on flares, complete repaint, etc, etc, when the cause of the symtom isn't established.
kqw 03-14-2005 01:43 PM
You mentioned measuring...What are your measurement front/back. Are you experiencing any bump steer?
stv951 03-14-2005 01:58 PM
John70t: I had the car lowered for both better handling and aesthetic reasons. Shocks are Biltstein sports in good shape-not new though
kqw: I had the car adjusted to Bruce Andersons specs after lowering it. High speed is important to me as well as fast road/track handling
What would be the best compromise in settings for this combination ?
Steering is quite heavy, but I don't mind. No bump steer
kqw 03-14-2005 02:11 PM
You have a few choices...
As you know, rubbing can be a dangerous hazard expecially at high speeds.
You can adjust your height a few fractions of an inch and add the inner plate as folks suggested or, roll the fenders and add the plate. Either way, it's important to eliminate that lip rubbing.
No bump steer at your current front ride height tells me that your setup was done correctly.
Besides your rubbing problem, your car must handle cornering like it's on rails...
stv951 03-14-2005 02:17 PM
Well its very good at the front, but I was experiencing alot of oversteer on the track - and I mean ALOT. I increased the pressures on the back as I was told by a friend from 40 to 43-44. Things were much better, but not perfect. Is that pressure too high ??? My car has 9x16 on 245s rear
adomakin 03-14-2005 02:30 PM
looks great to me!
if you can live with the height then go for it
Andy
Walko 03-14-2005 02:34 PM
What are your front pressures they might be relative to the over steer issue
Michael
jyl 03-14-2005 03:09 PM
That seems like pretty high rear tire pressures, if those are the "when cold" numbers. Add 3-4 psi when hot and you are running at 46-48psi!
If you are really interested in your tire pressures, take a look at the SmartTire tire pressure monitoring system sold by Tire Rack. I have it and find it interesting to monitor my pressures as I drive.
I've always thought front tire pressures should be roughly 3-4psi lower than the rears, as a starting point anyway. Would be interested to hear what others think/do.
What alignment specs did you use?
stv951 03-14-2005 10:04 PM
I'll check Smart tire pressure system. Is it accurate ?
I started with 36 fr and 40 rear when the tires were cold. Car oversteered and I almost spun in 3 or 4 occasions. Came back and added +3 psi on th rear wheels. Didn't touch the fronts, as they felt they were "glued" to the ground. I saw an improvement (6 seconds faster per lap ! so bad it was before) But still I thought it was too much pressure.
Can't recall the alignment figures as it was done some time ago.
Todd Simpson 03-15-2005 05:38 AM
Compared to stock, the 7's add some track to the front but not additional tire width. The 9's in the rear add lots of track and additional tire. I'm surprised you're getting oversteer at all.
Pressures seem high as well. I don't have any recommendations for street tire pressures but there are some in the archives. Think about the other cars that run a 245/16. Vette's, older M5's, those are heavy cars and may need 40 pounds but not a 911.
This is apples and oranges but with Yoko A032's I run 19 in the front and 23 in the rear on a fairly lightweight RS clone with a 3.2. Hot temps are in the mid to high 20's.
creaturecat 03-15-2005 05:59 AM
standard practise - roll the fenders
stv951 03-15-2005 08:03 AM
Are there any issues when rolling the fenders ? Could there be damage on the wing ? Rust issues ?
Tod:
Saw your car. Looks great ! Did I read correctly ? 19 fr and 23 rear ? So low ? Aren't the tires underinflated ?
It was my first time on the track with this 911. I tried something more than street pressures. Car was very VERY nervous on lift off.
Whats your idea on fast road/track tires ? Yokos are good ?
Do they work on the street ? A friend of mine just put Toyos RA1s on his... 750 BHP 996 TT. He is very happy with these. I know, its a completely different car, but... Anyone tried them ?
jyl 03-15-2005 08:05 AM
The Smart tire system is reasonably accurate - within a pound anyway, not good enough for racers but fine for me.
Are your tires perhaps getting old and worn? Is there anything weird w/ your rear suspension settings (maybe string, weight, and straightedge could at least tell you if something is very odd).
450knotOffice 03-15-2005 08:18 AM
Re: tire pressure and oversteer issues
Take this for what it's worth, but the Porsche Owners Manual for my '84 tells me 29 front and 36 rear. That's a 7 pound difference recommended by the masters of Porsche design themselves.
It sounds like you might have too much pressure and, more importantly, too little difference between the front and the back.
stv951 03-15-2005 11:31 AM
Thanks Scott. I'll try these. BTW are these meant to be for 16'' ??
Walko 03-15-2005 02:37 PM
Stv951
More negative camber should not make your car oversteer.
The only reason to add more neg however is if the tires are not working correctly (ie not getting to the proper temp across the whole tyre.
By memory toe in and toe out will change the stability of teh car in a straight line.
Now with the tires you are using I would assume that pressures you are quoting are hot.
I think you would need to beg buy borrow or steal a pyrometer (tire temp gauge) and check to see the difference between the innner middle and out edges of your tire after a few laps say three or four with no cool down.
Take notes and only change one end of the car at a time also keep note o fteh track temp as this will give you a yardstick for future track time.
Michael
T
