I've got my 3.2 engine for sale and decided to drive it to work one more time to make sure all was well before turning it over to a new owner. After starting, the idle was searching badly. It would almost stall then rev to 1000-1200 up an down, up and down etc. It got a little better after warming up but would still drop to super low idle and almost stall when coming to a stop. It is also running rich now. When you rev the engine it has a visable exhaust and you can smell it. Never did that before. The idle air control motor is running. Which sensor crapped out??
Mike |
Driving member
MIke,
what have you done lately to the car. I assume plugs, wires , rotor are all good. If it is not electrical maybe it is a vacuum issue.
Jerry '86 coupe gone but not forgotten Unlike women, a race car is an inanimate object. Therefore it must, eventually, respond to reason. |
Re: Super Erratic Idle
Take the car to your mechanic and have him adjust the mixture. You'll be good to go.
1984 Targa Last edited by scottb; 03-13-2005 at 07:22 AM.. |
Do a search on "Idle hunting". I posted the question a week ago. Plenty of info in this thread.
Cheers, Paul
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
I've Seen the Other Post
Thanks guys. I found the extensive post on this subject a few lines down.
timeless beauty
Check the cylinder head temp sensor, should be new updated one, if not the age of the old one is most likley starting to fail.
Bob 87 targa |
Licensed User
bump
Licensed User
bumping.....
Anyone? Im trying to buy this motor. 3.2 guys, please help! okay, adding some search results. Hope this helps Quote:
3.2 Fast Idle Frustrating Problem! 3.2 Idle Problem Last edited by Shuie; 03-14-2005 at 06:41 PM.. |
Will program for food
Is it still not resolved?
Greg Hnat 87 Targa Disassembled 90 944 S2 Auto-x, DE and semi-daily driver 98 Jeep Cherokee |
