GOT TURBO..
C I S fuel gauge's thread size ????
Does anyone know what the exact size is on the male to female fitting for c i s. I dont have a thread messuring tool,any my threads are strip'd,so im trying to find out where to get them..thanks
jimmy @ mobile works(sac-chico-vallejo) |
I'm not sure which fitting you're asking about, but here is a list of what was on my 930 engine when I converted to Aeroquip. If you can determine the diameter of your fitting, I would assume the thread pitch will match up with similar fittings on my spreadsheet:
993 |
GOT TURBO..
Thanks c.t, the one i need is the tap in lines for the warm up regulator.My female stripped out,and no one knows what i am talking about when i call them...
I believe all of the fittings to hook up the gauges are 12-1.5 and the larger ones on the filter/accumulator are 14 - 1.5. There is also another thread that is close enough (this from an aeroquip specialist) thats what he gave me and it worked perfect. I dont remember what thread it was. Try taking it to a aeroquip specialist and see what they can do?.
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
12x1.5 on my WUR.
Elombard, I'd be interested to know what that other Aeroquip size is. I shelled out for metric/AN fittings or adapters at each fitting.... Some of the carb fittings are correct for this.
993 |
GOT TURBO..
Thanks to all....
Cow
I just realized it was a fitting on my cheap gauge that was "close enough" not the metric fittings, sorry for the confusion.
