a/c belt removal
I need to remove the a/c belt so I can pull the plastic air guide out to get at the alternator. I cannot find anywhere that tells me how to remove the belt. Can anyone help, or provide advice on how I can pull the air guide out past the a/c belt? I have three more nuts to unscrew on the bottom half the the guide before it releases and I can't get at them as the a/c belt is getting in the way.
Many Thanks Ash |
You need to release the bolts that are holding the compressor and move compressor toward the engine to give you some slack on the belt.
Compressor typically mounts on a pedestal with 4 x vertical bolts that use a 12-13mm ( 1/2" ) hex head. There is a fifth bolt....pointing out horizonatally to the right...that must be loosened that determines belt tightness......
Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Thanks. I will loosen the belt this evening
