Engine Code ID help Please
The ID code is 911 84
The serial number was either never there or has been ground The heads are date stamped 4-71, 5-71, 6-71 and 3-72. They have a number k1819 also. The cam boxes are numbered 901.105.111.OR. The case is number 901.101.102.7R |
Engine type number 911/84 identifies it as a Californian '76 2.7 911S.
The numbers you list for the cam boxes & crankcase are casting numbers not part numbers. |
Thanks!
| All times are GMT -8. The time now is 12:46 PM. |
