2.7 CIS injection tuning help
I have been trying to richin the mixture on my 74 2.7 motor. I have never had a problem doing it on the 3.0 SC motors but I cant quite figure it out on the 2.7. Is it the same size allen wrench? I tried it and a few others with no luck. I know the hole is a bit different then on the SC's but.... Can anyone give me some advice. thanks
Is it the standard 3mm allen wrench?
It's also 3mm on a 2.7; the wrenching feature (inside hex) on the screw may be full of dirt. Try cleaning it out with some mineral spirits on a long (wood stick type) cotton swab.
Heres my 2 cents,stick the allen in with the car off. sometimes they end up getting a bit rounded when the prior guy dont know what size it is...Also check your adjustment on the senor plate.
Thanks for the input, I will give it a try.
| All times are GMT -8. The time now is 02:07 AM. |
