-   -   32 degree vent temps with r134a???? yup.... (http://forums.pelicanparts.com/porsche-911-technical-forum/211526-32-degree-vent-temps-r134a-yup.html)
Mark Wilson 03-17-2005 01:04 PM
Just had the Duckís AC refit with the new Rennaire serpentine evaporator and am very pleased with the results. Charged with r134a, we hit 32 degree vent temps on an 83 degree day. My ac is setup with stock condensers with a Procooler and this new evap. Seems to get more air volume though the vents as well. Next step is to finish installing a set of their new lightweight barrier hoses to replace my stock ones (ran out of time on this trip:(). Iím ready for the Dallas summer!!!!!
http://forums.pelicanparts.com/uploa...1111092580.jpg
http://forums.pelicanparts.com/uploa...1111092597.jpg
http://forums.pelicanparts.com/uploa...1111092667.jpg
http://forums.pelicanparts.com/uploa...1111092694.jpg
http://forums.pelicanparts.com/uploa...1111092725.jpg
http://forums.pelicanparts.com/uploa...1111092825.jpg
Mark Wilson 03-17-2005 01:05 PM
Results.......
http://forums.pelicanparts.com/uploa...1111092866.jpg
http://forums.pelicanparts.com/uploa...1111092930.jpg
http://forums.pelicanparts.com/uploa...1111092963.jpg
(come on....one more degree.......squeeze.....)
http://forums.pelicanparts.com/uploa...1111093187.jpg http://www.pelicanparts.com/support/smileys/wat6.gif
930addict 03-17-2005 01:14 PM
Nice. Where did you get the setup and how much did it run you? I'm thinking of upgrading my A/C.
Mark Wilson 03-17-2005 01:31 PM
You can check the info on procooler.com.
911pcars 03-17-2005 01:35 PM
Mark,
Why the prop rod? Did you add anything heavier to the lid or is it just a worn gas shock? I've got a solution in case you're interested.
http://forums.pelicanparts.com/uploa...1111095279.jpg
Sherwood
www.seinesystems.com
FrayAdjacent911 03-17-2005 02:03 PM
That's one thing I'm gonna miss on my '70. NO AC. In Texas, that's almost suicide. Luckily my 'other' car has the AC, and it WORKS!
tcar 03-17-2005 02:14 PM
Had a prop rod also, I got another new gas lift and it would sort of hold the lid up.
What I did, was get longer bolts, put one lift on the left side of the bracket, a nut between and the other lift on the right side of the bracket. Works great.
jriera 03-17-2005 02:15 PM
That's amazing Mark!! .. by the way you need to fix the clock.
Now I have to convince Ron to do a road trip to Las Vegas to do my car, new hoses, procooler and evaporator.
rfuerst911sc 03-17-2005 02:16 PM
Nice evaporator it appears to be a o-ring style vs. flare fitting,I am still struggling to get my flare fittings to seal.Nice setup you have there.These cars can have functional AC it just takes some work.
Mark Wilson 03-17-2005 08:38 PM
Sherwood,
Just looked at your new strut. Great idea!
Jordi,
You're gonna need the AC before long... How's the beast?
Rfuerst,
You might want to try some of that blue gunk/sealer stuff that the AC guys use. I think Ron used it on flare fittings as well.
masraum 03-17-2005 09:30 PM
I thought it was really bad to have the lid propped up while running the AC? Something about the gas condensing to liquid and then blowing the system up or something.
Mark Wilson 03-18-2005 04:35 AM
Yup, the lid should be closed when running the ac so the engine fan will pull air through the condensor. What you can't see is the high volume fan sitting in front of the lid supplying air.
88911coupe 03-18-2005 07:37 AM
Congrats Mark...I was wondering which you felt was the most beneficial, the Procooler or the new evaporator? Summer here in Tulsa was just about as bad as Dallas so I'm looking for any ideas.
Later
plain fan 03-18-2005 07:54 AM
Yeah but Tulsa is cooler than Okc in the summer (believe it or not)
Mark Wilson 03-18-2005 08:14 AM
Hey Buck,
I'm not sure if it's and either/or deal. We were getting 40 degree temps with just the Procooler on Freeze 12. While it was cold air, there still wasn't enough volume and I really wanted to go 134a to standardize. I think the evaperator was another link in the chain to maximize efficiency. The new evaperator seems to flow more air into the cabin we were definately getting cold air.
Tyson Schmidt 03-18-2005 08:20 AM
That's great! I'm surprised it worked so well with the decklid up, since you aren't getting any airflow through the decklid condensor that way.
One of the most important upgrades we did to Jack Olsen's car to get the 37 degree vent temps on high fan speed, was to update the evaporator to the '86 and later unit. I'm very interested in that unit you've got there.
brcorp 03-18-2005 08:21 AM
Re: 32 degree vent temps with r134a???? yup....
Mark, Great job!
I talked to RetroAir but they didn't want to sell individual parts only the total package. What did you pay for the evaporator? Also the hose that is being held up in the pict looks like a #6 vs the factory #8, am I correct?
Tyson Schmidt 03-18-2005 08:22 AM
Oh, I just read the above post about the fan. That explains it.
Mark Wilson 03-18-2005 08:49 AM
Re: Re: 32 degree vent temps with r134a???? yup....
Originally posted by brcorp
Mark, Great job!
Bill,
I think the evaperator was $229. He has prices on his website at procooler.com. The new hoses are smaller OD, but the same ID as factory. They're more flexable and ~10 lbs light than stock as well. I ran out of time over the weekend and didn't get all the hoses installed yet, but plan to redo in a couple of weeks.
Joeaksa 03-18-2005 09:08 AM
Mark,
Looks nice! Remember my summers in Dallas and its not a pretty sight with a stock 911 A/C system! Phoenix is warmer but no humidity!
JoeA
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
