strep's Avatar
Help !!!
I have been redoing my interior. I have got new handles. The passenger one works fine with the auto lock feature. When I put the driver side on the auto lock locks then pops right back open. I am assuming something is jambed[maybe]. Is anything anyone knows of could be the problem. Again w/passenger side on no probs. Driver side is the prob. Thanks
Old 03-20-2005, 11:51 AM
Are you talking about power locks or locking the door and closing it and having it remain locked. If it is the latter, the drivers side door must be locked with the key. You cannot lock and close door on drivers side. This keeps us idiots from locking keys in car. I hope this helps.
69 911 2.3Ez
85 928S
Old 03-20-2005, 12:29 PM
Bland
unclebilly's Avatar
Originally posted by jstobo
...the drivers side door must be locked with the key. You cannot lock and close door on drivers side...
Not quite, you can close it (and it will stay locked) if you hold the latch while you close it.
Old 03-20-2005, 12:33 PM
strep's Avatar
I have always used my alarm to lock and unlock the doors. I did not have this problem before. So I am talking about just using my remote to lock and unlock.
Old 03-20-2005, 12:36 PM
Does each door use a seperate elec relay ?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 03-20-2005, 12:40 PM
strep's Avatar
I am not sure.........I had no problems prior. Again with the passanger side only locks and stays locked. When I install the driver side. Locks both sides then both side pop back open.
Old 03-20-2005, 12:43 PM
strep's Avatar
Fixed !!!!! Thanks to all that helped !!
Old 03-20-2005, 01:30 PM
Administrator
Jack Olsen's Avatar
For future reference, don't use a subject line as vague as "Help!!!", okay?
Old 03-20-2005, 05:44 PM
