coloradoporsche's Avatar
Angry Look what I found
I pulled this out of my new-to-me 79SC.....
It was extremely difficult to remove, and I knew it was stripped as soon as I started backing it out. I was able to put a new one in the hole, and it went in "pretty far" and then got "pretty tight". And the car seems to run fine....for now.
Has anybody else driven around with a sort-of stripped out spark plug for any length of time? I guess I'm about to find out how bullet proof this SC really is.
If I do contact the PO, and he can provide a receipt for a shop that did the last spark plug change, do I have any recourse?
I suppose this is another reason to get the leak down done before buying! The seller seemed so honest.....
Old 03-20-2005, 09:30 AM
pwd72s's Avatar
Is it my eyesight, my screen, or are the threads on the plug itself bad???
Old 03-20-2005, 09:34 AM
Well, the stuff at the end of the plug appears to be melted aluminum. It flakes off in silver powder when I scrape on it. And some of the threads on the plug are crooked. So I assumed it was cross-threaded, but I'm not 100% sure what went wrong here. All of the other plugs came right out, clean.
Sheena is a punk rocker
Suzy Is A Headbanger
Heidi Is A Headcase
Judy Is A Punk
The Ramones' earliest titles included 'I Don't Wanna Walk Around with You,' 'I Don't Wanna Go Down to the Basement,' and 'I Don't Wanna Get Involved with You.' Dee Dee later said, "We didn't write a positive song until 'Now I Wanna Sniff Some Glue'."
Old 03-20-2005, 09:39 AM
sushinav's Avatar
I'd recommend chasing/cleaning the threads in the head ASAP. You can do this if you have the correct tap and die set, or make your own by cutting 2 grooves perpendicular to the threads on an old sparkplug, then working it in slowly and backing it out frequently to remove metal bits.
...sick with gearheadia
Old 03-20-2005, 10:21 AM
ruf-porsche's Avatar
Buy yourself a spark plug thread chaser and chase the threads out or bring it to a mechanic. Reinserting a new spark plug into a head with cross threads is just aasking for trouble further down the road.
Old 03-20-2005, 10:24 AM
What you have is an example of galling. This occurs when a tiny bit of the aluminum head bonds (welds) to the plug through friction as it is unscrewed. Once it starts it just gets worse. This problem can be entirely prevented by the use of a little anti-seize on the plug threads. There are many old wives tales circulating to the effect that anti-seize will disrupt the heat flow and cause the plugs to run too hot or too cold. This is patently nonsense, but even if true could be easily dealt with simply by using a different heatrange plug.
You may get by simply chasing the threads if they are not badly torn up, but will probably need to have an insert installed. This is best done on the bench, but given the expense, can be satisfactorily performed in situ by someone who knows what he's doing. If you go this route be sure that the tech knows his stuff because failure means the certainty of engine removal and breakdown.
regards,
Phil
Old 03-20-2005, 12:24 PM
Hey Everyone,
Thanks for the responses. I really appreciate the help. If I do decide to take the head off, do I need to drop the engine or can it be done from above?
Heidi Is A Headcase
Judy Is A Punk
Old 03-20-2005, 01:36 PM
Nitrometano's Avatar
Remove the valve cover and the engine sheet metal from that side. You will gain some space. Indeed if you need a more space. Put a jack and towers under the engine and loose it from the engine mount. Down the engine a bit. Be careful.
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 03-20-2005, 02:37 PM
H20911's Avatar
If you do chase the threads with a tap put a little grease on it to grab bits. also take your time and clean the tap completely several times adding fresh new grease each time. Oil might let some of the bits get in the cylinder. Obviously not really a great option but if the damage is not too bad you might be okay with it without the tear down.
Lastly anti-seize is your friend.....a good friend indeed .
h20911's V8 Homepage
www.home.earthlink.net/~sdfranco/index.html
Old 03-20-2005, 02:55 PM
Crew Chief
prooutlaw's Avatar
Very well put Noah.
Herbert B.
GruppeB #093
Carolinas Region PCA Member
National PCA Driving Instructor
_______________
'71 911 RSR look
'74 914 2.0
'76 911S Targa
'83 930S Slantnose (13000 miles)
'86 951 Prototype Testcar built in '84 (56000 miles) Serial #00014
'86 951
'87 944
"Life is short , drive Fast"
Old 03-21-2005, 05:21 AM
Recreational User
porschenut's Avatar
No way you can pin this on the seller.
Old 03-21-2005, 06:35 AM
Hello,
As you can tell from reading my original post, I did not know what galling was, so please give me a little slack here. My assumption at the time of the original post was that the plug must have been jammed in with about as much force as it took to get out Thanks to this forum, I have a much better understanding up what may or may not have happened to cause this problem.
I don’t think my reaction was atypical for somebody that bought a car and then finds a potentially serious problem the first time they change the plugs. All I said was that the seller seemed honest, and the feedback here has confirmed that he probably was. So, I don’t feel that I slandered anyone. (slan·der: A false and malicious statement or report about someone) A simple "I don't think the seller knew" would have sufficed.
That being said, I really do value the feedback with regard to the seller's probable innocence here. It gives me some peace of mind and I appreciate you guys addressing that issue.
Thank you.
Heidi Is A Headcase
Judy Is A Punk
Old 03-21-2005, 08:21 AM
