e-cams
Hi,guys,I'm building a 2.7 with early e-cams which have the extention on the back end for mfi but I'm using webers so the cams won't fit in the housings.Can I cut the extentions off flush with the back of the last bearing without disturbing anything?Thanks,T.C.
I might think about that one. I for one wouldn't. I beleive that you can take the plug out of the cam carrier and install a seal.
I'm going to use one to provide either a cam sync for an ignition or use it to drive a second distributor for a 12 plug motor. Good luck, David Duffield |
Or you might find that (and I don't know, just surmising) that the E cams have value to the MFI crowd, and you can sell or trade them for something similar, like a Solex set.
Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B] |
I ran a cam with the pully on my old '71 S with Webers with no problem, you just need to use a seal like David said.
86 Carrera Targa - Garnet Red Metallic 88 928 S4 - Gran Prix White |
I have your setup in my car. At first, I used the factory seal with the nose of the cam sticking out. Then it developed a leak. Not wanting to drop the engine just to replace the seal, I had a machine shop fabricate an aluminum block that covers and seals the area. It attaches to the cam carrier with two bolt holes and installs with a minimum of engine sheet metal removal.
This route sounds easier than R&R'ing the cams and having the nose machined off. It also provides more options for the next owner of your cams. Hope this helps, Sherwood |
I had mine machined off when I had my engine put together. I've found in the past that leaving little things like that as a possible option for myself or somebody else later never comes to fruition & just takes extra time, money & effort at the time. Of course I never plan to sell my car.
Marv Evans '69 911E |
Whack it off!
That is one of the most likely seals to leak. I put solex cams in my car that had the snout on the end. I cut the extension of with a chop saw and never looked back. One less place to leak. Jess |
I used an air cut off wheel to grouve around the shaft and a whack. Clean up with a die grinder.
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
