copper's Avatar
Crank Case Breather won't budge - Suggestions?
Whilst tearing things apart, I took the 4 nylock nuts off the breather cap to replace the gasket. The nuts are off, but the cap won't budge. It's a large cause of my oil leaks, so I need to change it.
The nuts and the hose are off. Any suggestions?
Also, the end of the hose that connects to the breather is soaked in oil. Even on the outside. Thoughts on why?
Jim
Jim Dean LL.B. - London, Ont, Canada.
1969 911T "Blood Orange" Euro (Brought over from Germany in 86)
Engine and brake system rebuilds 2006 & 2007
"Oversteer scares passengers, understeer scares drivers."
Old 03-21-2005, 02:31 AM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
Tap on it w/ a rubber mallet & it should come off.
Old 03-21-2005, 03:18 AM
copper's Avatar
I'll give it a try. Wanted to make sure I wasn't missing anything...
Old 03-21-2005, 03:22 AM
YTNUKLR's Avatar
Nope, sounds like you're not missing anything... Tap upward-ish on the tube part. Not too hard, but it should budge.
Old 03-21-2005, 03:23 AM
Bird. It's the word...
Fishcop's Avatar
Copper, when you put it back together make sure you linish the breather flat (600 wet and dry) and use something like hylomar or curil t on the gasket. I had a hell of a time with mine before I got it sorted
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 03-21-2005, 03:31 AM
copper's Avatar
Thanks John
Saw the bit about gasket sealer in Wayne's book.
When I put it back together, I'll do that.
Looks like it's put a lot of oil under the shround and on top of the engine case (currently have fan housing out). This is the cause of a lot of my leakage it appears.
Old 03-21-2005, 09:08 AM
