I just bought a new fiberglass ducktail on ebay. What are the best grille options considering lightweight, function, etc...??? And where to buy???
Thanks, Dan
Can I ask you a question? Sure, what is it? An interrogative statement that tests ones knowledge, but that's not important now.... '86 Carrera . . . '87 951 destroyed by drunk driver ... '01 Boxster S. . . '04 Cayenne S . . .
You should first determine whether it accepts the late plastic grill or the early metal grill. If it is new, I would bet plastic, which would be the same one you have on your Carrera now (Assuming it is sans tail). Metal grills are no longer made, but can be purchased on e-bay for $50-75.
Gone but not forgotten - 1980 Porsche 911SC w/ -22mm/28mm Torsion Bars | Custom Valved Bilsteins | 22mm/21mm Carrera Sway Bars | Elephant Poly/Bronze Bushings | Carrera Brakes | AJ-USA Brake Cooling | Carrera Oil Cooler w/ Fan | Elephant Strut Brace | Oh, and no ABS or PSM or A/C |
Friend of Warren
I think all the aftermarket ducktails are designed use the early metal grills. You can use the later plastic grill but you will have to do a bit of cutting on the edges to get it to fit.
Kurt V No more Porsches, but a revolving number of motorcycles. |
I used my stock grill with a ma shaw duck tail, it fit fine.
Jack 87 Carrera |
To save a pound or so, you could get some Al gridwork and then put a rubber gasket around it.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
I used early polished metal grill.
Many have used the plastic grill which is found cheaper on Ebay. To reduce weight, how about expanded metal in aluminum powdercoated black.
Luke S. 72 RS spirit 2.7mfi, 73 3.2 Hotrod on steelies, 76 993 3.3efi TT, 86 trackrat, 91 C4s widebody,02 OLA winning 6GT2, 07 997TT, 72 914 v8,03 900 rwhp 996TT |
I just bought a new grill from Porsche and used it with my MA Shaw ductail...the dimensions around the opening worked perfectly
Luke - got a pic of this? Not sure what you mean...
