-   -   Trailing arm refinishing? (http://forums.pelicanparts.com/porsche-911-technical-forum/212100-trailing-arm-refinishing.html)
JonT 03-21-2005 08:58 AM
I searched on plating and found lots on spring plate plating but what are guys doing to their trailing arms? Yellow zinc? powdercoat? Rattle can?
ghnat 03-21-2005 10:49 AM
I am going to powdercoat most of my rear suspension, just removed it over the weekend.
MichiganMat 03-21-2005 11:18 AM
polish
jyl 03-21-2005 11:26 AM
I left the trailing arm as-was. The bare aluminium looks nice, there's no rust problem, the part doesn't get that dirty, and it is not particularly visible either (e.g. through the wheelwells).
David 03-21-2005 11:29 AM
I polished a cast swing arm on a motorcycle once. It look great for a while and then it looked like crap. I'm planning to grit blast mine and leave them like that.
Wil Ferch 03-21-2005 11:33 AM
Simple cleaning of the aluminum version was all that was needed ( remove cosmoline) to look good....I presume we're not talking steel piece.
Wil
JonT 04-18-2005 03:43 PM
Has anyone ever painted their trailing arms? MichiganMat--how did you polish yours?
304065 04-18-2005 04:14 PM
The trailing arms are pretty soft metal-- you could polish them, or send them to be polished, like Gunnar Racing does, but by the time you get done beating on them, dropping them, slamming them into the torsion bar tube, scratching them with the spring plate, jacking them up, getting grease on them from the CV joints, heating them with a torch to install bearings or monoballs, and just generally abusing them, you'll be happy that they are UNDER the car and not sitting on your coffee table at home.
Nor would I paint or powdercoat them. If a crack develops, you want to be able to see it clearly, and remember, they are under the car. If you drive off-track they're going to get scratched and beat up.
I say pressure wash them, scrub them with a scotchbrite and call them cool.
Evans, Marv 04-18-2005 05:01 PM
I cleaned mine up until they looked nice and then sprayed them with clear enamel (Rustoleum, Sp?) I thought that would make them easier to clean when on the car and hopefully prevent corrosion for awhile.
lateapex911 04-18-2005 05:13 PM
Jeeeez John...you make so much sense it kills me! I was going to powdercoat mine clear.
MovOvr1 04-18-2005 06:03 PM
Anybody have any pictues????
JonT 04-18-2005 07:59 PM
Here's a pic to show what the brush can do
Just a few seconds with the wire brush-wow what a diff. I'll post a few pics when I'm done.http://forums.pelicanparts.com/uploa...1113879562.jpg
randywebb 04-18-2005 08:55 PM
If I had mine off again, I'd do that baking soda blast I think. Otherwise, power wash & Scotchbright or somethng like Jon T above. Something that doesn't take much time... they ARE under the car...
I cleaned mine in a parts washing tank and rubbed them down with Linseed oil and Rottenstone... no wait, that was something else....
304065 04-19-2005 05:50 AM
Don't use a steel wire wheel on them. The steel particles will embed themselves in the soft aluminum and rust, making the arm look worse.
randywebb 04-19-2005 10:57 AM
A good point -- use brass. Or if that is too soft (unlikely) you can find stainless steel brushes too (tho they might still rust depending on how 'stainless' they are).
rexav8r 04-19-2005 11:49 AM
I just went through the same thing with mine...
Started with the wire brush on the drill - WOW that looks pretty COOL !! Then took them to the bead blaster to get all the nooks & crannies - WOW that looks even better ! I wound up buying a rattle can of metal etching primer and semi-gloss black rattle can from a Savage auto paint shop and the final product looked pretty awesome ! Sorry I don't haev any photos with me here, but I'll try to post a thread of some of it later this week....
I thought the semi-gloss black would hide some road gunk plus be fairly easy to wipe down....
JonT 04-22-2005 11:02 PM
here's the finished product waiting for installation
Installed ERP's monoballs, polished with a wire brush, wiped down with thinner and then sprayed 3 coats of Eastwoods Diamond Cote clear coat. Looks good now but we'll see how they do after a few track events.http://forums.pelicanparts.com/uploa...1114236022.jpg http://forums.pelicanparts.com/uploa...1114236084.jpg
Dixie 04-23-2005 05:05 AM
Polish them? Paint them? They're going to look like crap in a week....
I just washed the worst of the dirt off so they'd be easier to handle while pressing in the bushings. (Trust me, they were filthy when they came out.)
The only reason I plated my spring plates was for rust protection.
JonT 04-23-2005 07:29 AM
Ok Debbie Downer! You're probably right but damm(*&t they'll look good for a few hours/days until I drive it. Its just hard to put a dirty part back onto a car while its all apart.
randywebb 04-23-2005 11:34 AM
It'll be easier to clean if its polished.
No comment on whether this is worthwhile or not...
