 1972 2.4 T MFI: wrench told me to install 74S distributor and pertronix A very respected wrench told me that if I want to improve the performance of my 72 2.4 MFI T to install a 74 S distributor as well as pertronix. Does this make sense? What would the S distributor do? How about pertronix? Thanks. I |
 The '74 normal or 'S' distributor has exactly the same specs and advance curve as your stock '72 distributor!  Adding a pertronix trigger will do nothing to enhance the power level of your engine! <b>That person is attempting to blow smoke up your southern region! Whether that happens or not is up to you!!!</b> If your distributor has issues such as worn bushings, or sticking centrifugal advance mechanism ... they can be adressed and remedied! |
| All times are GMT -8. The time now is 08:45 AM. |
