-   -   Best Source for RSR Door Panels?? (http://forums.pelicanparts.com/porsche-911-technical-forum/212266-best-source-rsr-door-panels.html)
tom1394racing 03-22-2005 04:05 AM
I am ready to buy RSR door panel kits for my 1973 to RSR Clone project. I want to buy a high quality kit that replicates the original look. I konw that many of you have installed these in your early cars.
Any recommendations on the source for the best quality kits?? How about the Appbiz kits that I see on Ebay?
motion 03-22-2005 06:27 AM
Tom - Appbiz is well known as an excellent supplier of RS door panels. I have a set from them and am very happy.
Bill Verburg 03-22-2005 06:27 AM
I am happy w/ the App Biz product, great service and easy to deal w/ as well.:)
Briana 03-22-2005 07:06 AM
Tom,
On another note, I believe we're due for update #9.
adomakin 03-22-2005 08:42 AM
update-update-update-update-update-(with pics)update-update-update(lots of them)opdate-update-update..........................!
Andy
Jack Olsen 03-22-2005 08:50 AM
There are two (actually three) types Appbiz offers. There's the original 911R panels, with the leather release strap that new passengers tend to try and pull the door closed with. Then there's the RS America type, which is not period correct, but is easier to work with. Then they make an RS America type with the pull relocated to work with early doors.
More correct:
http://www.appbiz.com/images/DP6RVB.jpg
More user-friendly and robust:
http://www.appbiz.com/images/DP9RLB.jpg
yasir 03-22-2005 08:59 AM
Jack,
By replacing the door panels to RS style would i still get the solid thump of OEM door closing ? I have been very seriously thinking about doing this mod with my car,much cleaner looks ;)
MysticLlama 03-22-2005 09:50 AM
Don't forget that Pelican carries these same panels, and I think they are even less expensive than going straight to Appbiz.
Also makes it easy to order a few other things such as door seals, window seals, door light switches, etc. at the same time to make it all nice and fresh.
Don't forget the moisture barriers.
My doors actually thump closed much nicer than they did before with the old beat panels and hardware.
MysticLlama 03-22-2005 09:52 AM
Panels on Pelican:
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_interi_pg17.htm#item74
The ones with APBZ in the part# are the Appbiz ones everyone raves about. I just did the leather ones on my car a couple weeks ago.
tom1394racing 03-23-2005 04:11 AM
Do I need to order the moisture barriers separate from the door panels? I thought the kit from Appbiz included the moisture barriers.
Relative to updates on my RSR project....I am in the process of rewring the car so there is not much exciting to report or show. I will post an update with photos when the wring, lights and interior are complete within the next several weeks. If anyone is interested in anything specific, let me know and I'll post some interim photos.
I missed the deadline for the Parade Concours registration in Hershey. I plan to show the car at the "non-compete" car show. hope to meet some of you there.
Bill Verburg 03-23-2005 12:51 PM
You can do it either way, the packaging material can be used as a moisture barrier or order special die cut pieces for a nominal fee, I got the extra cost one and have no regrets.
http://forums.pelicanparts.com/uploa...1111611018.jpg
MysticLlama 03-23-2005 12:53 PM
Yeah, I orded the die cut ones separately. They were somewhere around $7 if I remember right, and all the holes are already there. Just get something to glue it on around the edge with and you're good to go.
jpahemi 03-24-2005 11:37 PM
Porsche still sells the water barrier shield which is cut perfectly and has adhesive; peel and apply, no glue. Autos International makes the best door panels; the material matches perfectly, not to mention the accuracy of the trim locations. Compare Appbiz to the REAL RS/RSA panels and you'll see the difference.
J.P.
cantdrv55 03-25-2005 12:32 AM
Do you have to cut out holes for power window switches or can you order with holes already pre-cut?
widebody911 03-25-2005 06:37 AM
On the AppBiz panels, they're shipped with a heavy-guage plastic bag holding the panels; you re-use this bag as the moisture barrier.
All of the holes you need are die cut in the panel; you simply cut the fabric/leather for the stuff you need, ie electric window switches or speakers.
Bill Verburg 03-25-2005 06:45 AM
The extra cost barrier has the holes pre cut, the packaging method does not.
Joe Bob 03-25-2005 07:00 AM
My vote APBIZ....class act.
randywebb 03-25-2005 12:37 PM
I've seen one other post like Jpahemi's re the AppBiz.
So it may be a choice between an xlnt product and a perfect match product... decide what you want.
