flipper's Avatar
Porsche Crest Exhaust heat shields
I have a Bursch exhaust and it seems like the pipes are really close to the valve covers. Should I put a heatshield of some sort between the two, or maybe wrap the pipes? What do you all think?
2005 911 carrera
57 BMW r50, 2007 Ducati s2r 1000
2007 Boxster (sold)
77 2.7 911s chocolate w/ducktail (Mr Hankey) (sold)
77 930 black (sold)
Old 03-22-2005, 08:19 AM
flipper's Avatar
I wonder if wrapping them would make it run hotter?
2005 911 carrera
2007 Boxster (sold)
77 930 black (sold)
Old 03-22-2005, 10:29 AM
Yellowbird RS's Avatar
If you are running hot try the
HEETSHEET
X/A
Old 03-22-2005, 10:40 AM
Unfortunately, the Bursch and other performance headers run very close to the lower valve cover. This prevents proper installation of the HeetSheets which rely on creating two air gaps between exhaust piping and valve covers to reduce temperatures the engine is exposed to.
In our tests, we measured as much as a 60 degree difference with the HeetSheets in place using factory heat exchangers. Wrapping headers with thermal tape reduces radiated heat but shortens the life of the header material. Ceramic coating is a good option.
Sherwood
seinesystems.com
Old 03-22-2005, 06:00 PM
