LinkBack | Thread Tools | Rate Thread |
To examine/clean the steering column switches, steering wheel must come off too?
Does the steering wheeel have to come off if I want to look at the steering column/turn signal stalk switches? (Removing the two little screws doesn't seem to fully release the plasitc housing )
(I just want to clean them) thanks
1969 911 E Coupe "Little Bull" "Horse" "H." Heart, "G." Gears, and "P" the Porsche |
Bird. It's the word...
I can't tell you for sure, but I can tell you the wheel comes of pretty easy - just need a 27mm socket.
John Forcier Current: 68L 2.0 Hotrod - build underway |
Wheel will need to come off, there are 3 or 4 very small screws under the wheel to completely remove the upper/lower cowl cover to gain access to switches.
Here you go. Remember to hook up the ground on your way out.
89 Carrera 3.4 "There is a right way to go around a corner - it's called the line." -- PCA DE speaker bryteside.com - good things happen. |
