no passenger side tail lights after partial engine drop
just completed replacement of seals on oil cooler good news very dry bottom I did the partial drop now the tail lights on the rt rear not working bulbs ok has any one had similar experince did Ipull something loose thanks to all
Did you check the wire connections at the tail lights? I'd start there and trace backwards. Also, please post your year etc. It might help? An older vehicle might be easier to disrupt the connections after the drop. Also, did you remove the bumper/cover or just raise the rear end a bit higher?
thanks for reply my car is 86 911 cab gaurds red I did not do a complete drop just a partial
| All times are GMT -8. The time now is 07:33 PM. |
