TOO RUF's Avatar
3.2 EFI Manifold on a 3.0
From what I have read it looks like the 3.2 intake manifold will bolt up to a 79 3.0. Is it necessary to Port match? Can I use this injection system with a Megaquirt Computer? Will the megasquirt work fine with the Turbo Charger I am installing? This just seems like a easier route to add EFI to a 3.0.
15 Cayman
93 Amethyst 964 Cab & 67 21 window VW Wife's
64 356
69 912 targa
68 911L Hot Rod
Old 03-22-2005, 04:07 PM
Navin Johnson
TimT's Avatar
Dont have to port match, especially if your going to be "pressurized"
the 3.2 manifold is a popular way to convert to EFI, We have done a number of cars this way.. but use Haltechs
You will need a 3 bar MAP sensor to use with the Megasquirt
'69 911 GT-5
'75 914 GT-3
and others
Old 03-22-2005, 04:24 PM
Measure the 3.2 port openings...they vary from 39-42 from the factory. Now measure the port entrance on your heads. See the difference? I would at least match them that is a large difference. Throttle response will be better as well. Tim...have you considered using Accel units?
Eric Hood
Old 03-22-2005, 05:48 PM
Navin Johnson
TimT's Avatar
No, We have a very good relationship with Haltech
'69 911 GT-5
'75 914 GT-3
and others
Old 03-22-2005, 05:54 PM
oh..ok I was going to introduce you to an Accel guy up in your area if you were interested. Are you the one that is getting "abused" over the gt35r?
Old 03-22-2005, 05:58 PM
Navin Johnson
TimT's Avatar
nuther tid bit of info,
you have to be kinda creative with the connections to the throttle body etc...
'69 911 GT-5
'75 914 GT-3
and others
Navin Johnson
TimT's Avatar
dont know what a gt35r is
'69 911 GT-5
'75 914 GT-3
and others
Old 03-22-2005, 06:00 PM
My mistake...the guy on rennlist calls himself turbo tim He is selling gt35r turbos and is getting attacked by the HF people.
Old 03-22-2005, 06:03 PM
tbitz's Avatar
No need for a 3.2 manifold. You can use your existing CIS manifold and still get EFI. Details here:
http://www.bitzracing.com
Cheers.
Tony
'78 911SC with BITZRACING EFI conversion kit
Old 03-22-2005, 07:22 PM
TOO RUF's Avatar
Tony,
I have a cast aluminum airbox and working CIS. I would rather sell that and start with a 3.2 manifold. Then I could use a megasquirt with o2 sensor.
15 Cayman
64 356
69 912 targa
68 911L Hot Rod
Old 03-25-2005, 09:07 AM
