TargaRob's Avatar
Question turn signal anxiety
...so my turn signals went out but all other lights worked, even the hazards...so i intented to replace the turn signal assembly, but i don't know what the black/white/green wire connects to...any help on this would be great...thanks
Rob Owen
- 1980 911 SC Targa
911 Design
Parts Manager
Old 03-25-2005, 08:21 AM
TargaRob's Avatar
bump
Rob Owen
- 1980 911 SC Targa
911 Design
Parts Manager
Old 03-25-2005, 05:26 PM
greglepore's Avatar
Check the connector from the turn signal harness to the main harness-its under the dash, left side, can't remember what it looks like, but I managed to knock mine loose while working under there and had same symptoms.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 03-25-2005, 05:51 PM
TargaRob's Avatar
well...i fixed it. the search turned up a good check list from flintstone, i started back from the flasher. power when the e lights on, no power with key. checked all the fuses 3 times. pulled the relay at least 6 times. finally i got power with the key, then no power. I couldn't figure it out. I went back and cleaned all the ground connections, rechecked all the fuses again. I turned them all twice. Here's the clincher, the fuse to the flasher/blinker/tail light looked good,but i figured i would clean it. I took it out cleaned it nothing, took it out again and low and behold...i hair line crack in the top nub area. new fuse and alls well. thanks to those for the great archives.
Rob Owen
- 1980 911 SC Targa
911 Design
Parts Manager
Old 03-25-2005, 09:22 PM
