930 Transmission
OK, the original 76' 930 tranny gear ratio is tall. What can I do to lower the ratio so it drives better in the city and gets better accelleration. I want better accelleration and shifting in the city not top end speed. Also can anyone recommend a good place to have the tranny rebuilt? Thanks
1976 930, mostly stock
Fly fast, drive fast!
1.19 Mach is my record
Love my 930
Hate Seattle traffic
Believe in the 10% rule
Old 03-26-2005, 09:39 PM
SC cams and/or a 5 speed conversion.
206 637 4071
Old 03-26-2005, 10:25 PM
Automotive Monomaniac
Emission's Avatar
He nailed it (as expected).
2018 - Porsche 911 Carrera 7MT / 2018 - Porsche Macan 7DCT / 1993 - Cadillac Allante / 2023 - RAM TRX (on order)
Old 03-26-2005, 10:31 PM
I believe this guy can rebuild your tranny. And he is right down the coast from you.
http://www.johnwalkersworkshop.com/
Dean
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 03-27-2005, 06:00 AM
David's Avatar
Put in 8:39 ring and pinion, Andial has them on their web site.
Old 03-27-2005, 06:03 AM
350HP930's Avatar
+1
Thats the route I am taking since I like the ratios between the gearset in the 930, I just wished that each was a little shorter.
The andial R&P will shorten your gearing by about 20% and is a lot cheaper than a G50 conversion or changing the gearset in the 930 tranny.
Old 03-27-2005, 06:24 AM
David's Avatar
I'm planning this change also. From what I can tell the ratios of the 930 with the 8:39 R&P is close to the first 4 gears in the '89 930 5 speed tranny.
Old 03-27-2005, 06:29 AM
350HP930's Avatar
I calculated that the R&P change would limit the top speed of my car to somewhere in the mid 160s which is more than fast enough for me.
Old 03-27-2005, 06:47 AM
