bb bb is offline
OK, I'm pulling my hair out...How do the driveshafts go back together
So, I am "finally" putting the motor back in the car (76'). As I am getting ready to bolt the axle's back to the tranny I get a couple of bearings fall out of the shaft. There seems to be 6 of them in the (I'm assuming the CV part of it) shaft. It seems to have the outer housing, the shaft an inner housing and the bearings. I am having no luck reassembling this so that I can bolt them to the car. Are there any trick's to this?
Oscar
Old 03-26-2005, 11:52 AM
bb bb is offline
I think that the part I am talking about is the CV joint. Can this be reassembled on the car, or am I going to have to assemble it off the car?
Old 03-26-2005, 12:04 PM
Still Doin Time
asphaltgambler's Avatar
Off the car, with care. You need to line the knuckle off-set to the round reliefs in the flange. If you look at the knuckle (the inner part attached to the shaft) it has even/odd shaped reliefs. The same for the flange (outer piece). It goes odd-to-even with all balls held in place with appropriate grease and some leverage.
Old 03-26-2005, 12:14 PM
Unoffended by naked girls
dhoward's Avatar
Send a message via AIM to dhoward
It's a lot like a Rubic's cube. Have fun. When it's back together right it will pivot freely. It's possible to get it wrong. It will be obvious if its wrong.
Dan
1969 911T (sold)
2008 FXDL
www.labreaprecision.com
www.concealedcarrymidwest.com
Old 03-26-2005, 12:35 PM
I think there was another thread on this subject, with pictures. Maybe try a search. The way the balls and cages go together is counterintuitive!
Old 03-26-2005, 01:24 PM
disband
juanbenae's Avatar
this may help>>cv joint reinstall
Old 03-26-2005, 01:44 PM
