-   -   Alternator Brushes- what is the minimum length? (http://forums.pelicanparts.com/porsche-911-technical-forum/213042-alternator-brushes-what-minimum-length.html)
wullie 03-26-2005 12:04 PM
Hello,
my alternator light is (lightly) shining when the engine is running 2500+ revs in my 1975 911s.
It is not the voltage regulator (already replaced it).
According to the 101 projects the alternator itself might be the problem. I opened it and I could change the brushes, if this should be the root cause.
Is my assumption correct? What is the minimum length of the brushes?
Regards,
wullie
Wil Ferch 03-26-2005 12:24 PM
Brushes have to long enough to make contact with the slip ring under a slight "spring push" basis....
Wil
Joeaksa 03-26-2005 02:01 PM
If you have the brushes out, replace them! They are not that expensive and the most difficult part is getting to them.
JoeA
