rotorhead's Avatar
930 Clutch
I am about to put my 3.3ltr back in and I noticed that the rubber center clutch disk had cracked. Si O need a new clutch disk. What are my options?
1. Another rubber centered disk,
2. a 3.0ltr spring centerd disk,
3. a kennedy disk,
4. Sachs power clutch disk?
This is a stock 930, what would you guys recommend?
2008 BMW 320i
2006 Mercedes ML320
2004 Mercedes ML270 cdi
1998 Porsche Boxter
1988 Porsche 930 Targa (sold)
Old 04-02-2005, 09:45 PM
rotorhead's Avatar
I forgot the photo sorry...
2008 BMW 320i
2006 Mercedes ML320
1998 Porsche Boxter
Old 04-02-2005, 10:03 PM
beepbeep's Avatar
Ahh...the usual.
Stock rubber disc will work for 10 more years, so in case you are not going to track the car and just need working clutch, I actually recomend stock disk.
3.0 discs need special lengthened throw-out bearing that's expensive.
Thank you for your time,
Old 04-03-2005, 01:19 AM
rotorhead's Avatar
Originally posted by beepbeep
.... 3.0 discs need special lengthened throw-out bearing that's expensive.
I thought that may be the case, our host has the following written above the selection of clutch disks:
"Note that the 1987-89 911 Carrera and the 1978-89 911 Turbo cars can be swtiched to the 911 Turbo 3.0L spring center disc with no modifications. "
Are you sure about the lengthened throe out bearing and do you know where I would get one? The one listed on the site is
Throw Out Bearing, with spring-centered disc, 911 Turbo (1976-88) H-116-081-11 $148.05
and it looks like a standard throw out bearing.
2008 BMW 320i
2006 Mercedes ML320
1998 Porsche Boxter
Old 04-03-2005, 01:50 AM
