Idle and air/fuel controls on SC
My first 911, a '78 SC from CA, will be here in a couple weeks. In the event that the car needs to be fine tuned to the WV climbate, how do I adjust the idle or air/fuel mix? I have a friend who owns an '83 which has the handy-dandy air/fuel screw that he uses to set the idle. I understand that the 78-79 does not have this feaure.
This borders on being a stupid question....but I honestly don't know the answer since I'm new to Porsche ownership.
Aaron
Old 03-27-2005, 08:40 AM
Designer King
Paulporsche's Avatar
This is adjustable on your car. The mixture is adjustable w/ a 3mm Allen wrench via a hole in the top of the air flow sensor assembly. The idle is set by turning the wide flat screw on the side of the throttle housing.
If you do a search, you will find a lot of info. The Bentley book also shows how to do this, and I think so does Wayne's "101 Projects".
I am not sure about CA. It is possible the mixture screw has a plug over it. This can be drilled out for access.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 03-27-2005, 09:05 AM
Thanks, Paul.
The seller is including a Bentley and 101 Projets, so I'll familiarize myself with the procedure when it arrives. Don't know why I thought the 78-79 didn't have this adjustment?!?
I'm looking forward to fiddling around until I find an ideal setting. The reason I asked in the first place is because my friends '83 ran great in Colorado, but crappy in WV until he adjusted the air/fuel mix. Thinner air issue I suppose.
Aaron
1978 911Sc
Talbot yellow
Old 03-27-2005, 09:31 AM
