Well I am not going to toss them !!
Toss them.
Looks good. I wish I had those instead of some water-logged cardboard pieces OS!
Whoa... I thought Appbiz had better fitting products than that. I feel your pain... when things don't fit.
You are right. It does look bad. The door panels are new and leather. If you can suggest how I might clean it up. Are the planels balloning because the cut for the speakers is to tight.
eBay is crying for these things.
Looks bad and...
If you were to ever get T-boned, you probably would wish you had stuck with the stock map pockets and top trim. :)
As far as the panel "ballooning" is concerned: It looks like the foam padding used is too thick, or not firm enough (as compared to stock) and/or the leather/vinyl used was not stretched tight enough around the panel. SmileWavy |
strep! It is the thought that counts! I give you an "A" for effort!
| All times are GMT -8. The time now is 06:58 PM. |
