-   -   Any Secrets to Replacing a Headlight Switch? (http://forums.pelicanparts.com/porsche-911-technical-forum/213350-any-secrets-replacing-headlight-switch.html)
Sunroof 03-28-2005 12:03 PM
I am going to replace my headlight switch in my 1973.5T and I noted the knob screws off, but I would have to configure some type of tool to remove that two holed retention piece.
The old switch looks like it will drop with wires attached for a re-fit with the new unit, although I have to lower my knee level A/C vent unit for better access.
Any recommendations, procedure(s) or cautions anyone can pass on who have done the same light switch R&R?
Bob
1973.5T
john walker's workshop 03-28-2005 01:02 PM
small needle nose pliers work for the retainer. otherwise, just swap one wire at a time. too bad about the a/c vent box blocking the view.
Sunroof 03-28-2005 01:54 PM
Thanks John.
I was thinking of fabricating something out of fork for the retainer piece, but I will try first with the needle nose. The knee level AC vent unit has on many occasions been a pain in the butt for accessing stuff under the dash.
Regards
Bob
LakeCleElum 03-28-2005 02:40 PM
I use the 45 degree angle tips for my "circlip" pliers.....
scottb 03-28-2005 02:48 PM
That's what I tried to do, but for some reason that retaining nut would not come off. John Walker graciously sent me a replacement after I used my Dremel to uh, er, persuade the retaining nut to part company with the switch.
The real trick, as John said, is to replace the wires one at a time. There are a bunch of 'em on that switch, and it's really easy to get them mixed up. Not a difficult job, but one that takes patience.
Good luck!
LakeCleElum 03-28-2005 02:54 PM
Don't feel bad, if I recall, mine was kinda stuck to the dash vinyl and took a little wack to get it started.....
