-   -   Ignition switch wiring sequence '70 T (http://forums.pelicanparts.com/porsche-911-technical-forum/213586-ignition-switch-wiring-sequence-70-t.html)
911-m5 03-29-2005 05:31 PM
I was having trouble with the tumblers and pulled the damn thing out. When I did all the wires fell out of the back. Could somebody tell me the order they go in or if it matters?
I have to sets of wires that plug into it -
3 wires: 1 each of yellow, red and grey
and
5 wires: 4 reds and a yellow
Thanks from a dummy!
project 911 03-29-2005 06:10 PM
Don't know if this will help or not...
http://forums.pelicanparts.com/uploa...1112148616.gif
911-m5 03-29-2005 06:49 PM
Thansk for the post. Hmmm
All my red wires are solid red - no stripes......
70 and 71 wiring different? Or has my car been rewired or something?
project 911 03-29-2005 06:53 PM
Not sure about that. The wiring diagram is labeled as 1971.
FrayAdjacent911 03-29-2005 08:03 PM
Sorry for the hijack, but I have a related question:
The ignition switch actually has the key cylinder as part of it? Mine works, but sometimes doesn't want to go all the way over to kick over the starter. I'm thinking about replacing it eventually, and the door cylinders and having them all keyed for the same keys.
project 911 03-30-2005 04:33 AM
See if this helps at all. The switch shown is from my 71, and the wiring plug is from a 78. I replace mine with the 78 unit and kept the 71 plug and everything worked fine. There should be a plastic cap on the back of that plug that holds the wires in place.
http://forums.pelicanparts.com/uploa...1112185757.jpg
911-m5 03-30-2005 04:33 AM
Bump...
Waiting for John walker to bail me out again....
911-m5 03-30-2005 04:35 AM
Hey that pic may help me out Project911. We must have posted at the same time.
Thanks!
911-m5 03-30-2005 01:18 PM
Is it still out of the car? Ciould you go around the nodes and tell me what goes where? I can see some of them but not all of them.
Can anybody else help me?
911-m5 03-30-2005 06:32 PM
desperate bump.
project 911 03-30-2005 06:56 PM
I'll be with you shortly...
project 911 03-30-2005 07:17 PM
This is about the best I can do. You should be able to tell some locations by the length of the wire if the bundle is still wrapped.
http://forums.pelicanparts.com/uploa...1112238963.jpg
911-m5 03-30-2005 08:01 PM
Thanks a bunch that should get me there. I'll try it tomorrow.
project 911 03-31-2005 03:39 AM
This may help too. You can see from this view the two spots that don't have a wire. (the black holes)
Hope this helps. I've been in the same spot with another plug that came apart and kept me off the road trying to figure it all out. Very frustrating!
Good luck.
http://forums.pelicanparts.com/uploa...1112269128.jpg
