964 Head Temp Sensor -- Adding a Gauge
The 964 motor comes with a head temp sensor for the motronic unit, right?
I'd like to get a look at my cylinder head temps while I test out some different aero items that might be heating up my motor. Can anyone think of a way to utilize the stock sender with a cheap gauge as a temporary solution? |
I don't know how precise your measurements would be. The factory manuals give a broad range for temp vs resistance. If all you care about is the relative temps then read on.
On these sensors resistance goes down as temp goes up. With a fixed voltage source (supplied by the DME) the current will go up as the temp goes up. You can measure the current flowing through the sensor without much trouble. To do this you could make a harness with connectors on both ends so you could plug the sensor into your harness and then plug your harness into the factory (car side) harness. Place a small value resistor (<10 ohms) in series with the sensor and measure the voltage across it with a high impedance voltmeter (digital not needle) to determine the current. (Voltage = Current * Resistance). (My cat told me this. I don't know nuthin' 'bout e-lec-tricity.) -Chris |
Jack,
I have an extra CHT gauge off of the plane that am not using right now. If you can give me an idea how to wire it or what terminal its off of would also like to have this. JoeA |
Joea,
The Porsche temp sensor "goes the other way" Negative Temperature Coefficient (NTC). It decreases in resistance as the temp goes up. A thermocouple (do airplanes use them?) temp sensor actually produces a very small current when heated. (Again, according to my cat.) -Chris |
You can get CHT sensors which just slip under the spark plug and replace the spark plug washer. Easy to install and you can move them around from cylinder to cylinder. Costs ca. $ 15.
http://forums.pelicanparts.com/uploa...1112205218.jpg |
Airplanes do use thermocouples to measure CHTs. You can even get six probe sensors so you can check each cylinder but that's getting into some cash.
The spark plug idea seems to be the best for a temporary installation. |
Many of the aircraft use a CHT sensor (as Blue above mentions) that goes under the spark plug or bayonet plug into the head. What type of gauge do we need to find and what are the values to be looking for? JoeA |
Okay, so I've learned I can get readings through the DME, but I need to turn the car off and disconnect the cable.
"Valid CHT sensor readings across pins 30, 45 of the DME plug per the Porsche shop manual (page D 24/28 - 12): 0 degrees Centigrade (C), 6.8 kilohms - 4.4 kilohms 15C - 30C, 3.6 kilohms - 1.4 kilohms 40C, 1.3 kilohms - 1.0 kilohms 80C, 390 ohms - 250 ohms 100C, 210 ohms - 160 ohms" Does anyone know if it's possible to piggyback a separate gauge off of the output from the stock sender? Would this mess up the DME's voltage as it comes in? I have an oil temp gauge wired to my tranny. Since this is a temporary thing, it would be great to simply bridge the factory sender and my existing temp gauge. Is this at all a viable idea? |
I think you should just get a head temp gauge and sender and keep it. It's a nice feature.
You should place it under the #5 spark plug. |
I think you need will needto get your diagnostic port hooked up.
Here is the relevant section of the shop manual Cylinder head temp http://forums.pelicanparts.com/uploa...1112217975.jpg ***Is auto resizing kaput again?*** |
Tyson,
I'm about to install a factory Carrera head temp sensor in one of my 930 heads. I have no current plans to monitor the temp or use the temp as an input for my injection system, but I thought that while I was at it, it would be good to install one. You said cylinder No. 5 is where to put it. I've heard cylinder No. 3 is the best place. What is your reason for saying cylinder No. 5? |
Is #5 the hottest?
Best location might be different for a 930 motor vs 964?
These thermistor circuits are non-linear. I like a good 'ol thermocouple. The under the spark plug gizmo is one - probably a type K. You could also get a fine wire one (Type K) and put it down where the resistive sensor is located. Omega is the WalMart [I mean that in a good way] of thermal sensors, process control, etc. They are on the web.
What's the typical head temp, and high end for a 964?
I'm thinking of biting the bullet and getting a VDO gauge to install permanently. At $110, it's going to cost more than the whole skirts-and-diffuser project it's monitoring the effects of. :rolleyes: http://www.bus-boys.com/vdo-cyltemp.jpg |
I'd not bother hacking into the car wiring. Seems like more trouble than it's worth. If planes get by with the thermocouple under the plugs............
I have the same gauge you posted Jack. http://forums.pelicanparts.com/uploa...1093786420.jpg Mine hovers around 300 all the time. Have yet to see it higher. But I haven't tracked it yet. We'll see what happens @ Blackhawk May 4. I like how it needs no power to operate. That's pretty cool. Electricity is like magic to me! egauges.com has good prices on the VDO gauge. That's where I got mine. Your $110 is what it'll cost from them. AutoMeter makes a cheaper gauge, but you don't get the luxury of the spark plug thermocouple. AutoMeter uses a threaded fitting you'd have to tap into the cyl. head. Or use the setup posted by buster with an AutoMeter gauge for a few less bucks total? Whatever the case, it's an easy install. The hardest part is mounting the gauge. If I can do it? Anybody can. |
From the data posted above, it looks to me that the DME sensor just reads up to 100 C. This might be enough for the cold start enrichment function, but will not help you much with your challenge. Typically the CHT will be between 300-375 F (150-190 C) and the max. limit should be 400 F (205 C). The spark plug location typically reads 50-100 F higher than other locations such as head studs. If the spark plug CHT sensors are a resistor type (?) you might indeed use them with an oil temp gauge. You would need either the specs of both sensors or better one of our electrical gurus to figure out how to connect or adjust for the range (sorry, I'm a mechanical engineer and try to stay away from life wires if possible).
I just ordered the 0-600 degree VDO unit. I'm going to make it a permanent install in my center console, which currently has a Voltometer and a Trans Temp gauge.
#5 always seems to be the first to detonate. The Factory uses the back side of #3 to install theirs, but I suspect that's more for ease of packaging |
Jack,
If you're really unsure about the effects of the aero package get 6 ring thermocouples and run them through e selector switch. John |
you'll love it. |
Is 400 degrees the 'shut it down, let it cool off' temperature (like 250 for the oil), or should it be lower than that?
We run the airplanes at 350-375 all day long with no problems. One issue is that the gauge does not normally react real fast, and aircraft engines are operated at a steady speed, where car engines vary their speed quite often.
Would love to see what Bruce Anderson or someone who has lots of dyno time chime in here and see what their limits are on the CHT. The aircraft engine makers generally recommend 400 or below. http://www.lycoming.textron.com/main.jsp?bodyPage=/support/publications/keyReprints/operation/leaningEngines.html http://members.eaa.org/home/homebuilders/building/engines/Engine%20Cooling%20Tips.html JoeA |
I dunno what the porsche experts recommend for their engines, but aircraft engines are rated for operating CHT of <400 F and red line is 500F.
it takes a few seconds for the gauge to react. The slow ga reading kinda balances the heat reading from a hotter spark plug during acceleration so you won't be seeing CHT spiking as with a digital reading. The plug is cooled thru the threads and the new CHT gasket. An acceleration from 3k-5k will need a few sec at 5k for an accurate reading. An analog CHT reading won't show the spiking, good. Detonation causes a higher CHT, not sure of the increase temps but a 25degF increase is a noticable increase from your baseline.
I would test the CHT reaction to different circumstances. Once you establish a baseline you'll be able to adjust your engine load. Simply stated I know what temp I need to pull away with a cold engine without bucking, when the CHT is ok for higher acceleration, when higher CHT begins to affect oil temp and to what amount, when to shift from 5th to 4th during mountian drives, when you're using the best cool down lap technique, etc. afaik 350degF should be max for a street&track engine. Shut down isn't necessary when you're CHT is high, just reduce the engine load. Cyl's 2&5 are a happy medium for a ballpark indicator. CHT's will vary among the cylinders. Some cyl's are more likely to be on the hotter side for a longer time than others. The hottest cylinder floats among all cyl's to some extent and 2&5 seem to be consistant "averages".. meaning the differential between the coldest and hottest cyl CHT may be 20-30degF and the differential between 2or5 and the hottest is usually 1/2 of that differential. 5th gear, high rpm is where the envelope lies. I don't think dyno circumstances is relevant besides knowing when the engine blows up. Conditions of street vs track vs dyno are extremely different. Every dyno guy I asked about CHT's just gave me a shrug and said "we don't pay much attention to CHT." CHT is great engine operation monitoring imo. my prejudical rant was learned on a street engine w/CIS & carbs using extreme CHT monitoring. |
CHT is great monitoring where EGT is great diagnosis imo.
http://forums.pelicanparts.com/uploa...1112254752.jpg |
Not having anymore information to start the project, this is a starting point to use the piggy back the a head temp gauge of the DME's CHT signal.
1. Measure the voltage that goes to the CHT from DME If 12 VDC Simple, if not see 2b. 2. Find out the input resistance of the desired gauge 2a. If it has high resistance (above 50,000 Ohms), simple 2b. If it has low resistance (below 50,000 Ohms), an Op Amp System is needed. (Simple 741 Op Amp will work) 3. Graph the resistance vs temperature characteristics of the CHT, check to see how linear it is 4. Perform bench test to see how VDO gauge works with CHT. Compare test data to calibrate gauge 5. Parallel VDO gauge with to the input on the DME. Hope this helps. (Received this information from Rocky, our Horse) :D |
| All times are GMT -8. The time now is 08:17 PM. |
