lateapex911's Avatar
Aluminum trailing arm advise?
I am re-doing the suspension on my '73 911, with T bars, shocks, poly bronze bushings, Wevo adjustable spring plate/needle bearing set up, rear monoballs, and so on.
While I'm there, I am considering upgrading to alum trailing arms. But the price of used ones is in the $300 range, plus refinishing and other costs.
So..the questions I pose to the experienced voices on the board are: What are the little things I will need, like brake lines, bearings, and so on that will add even more money to the project, and when all is said and done, is it worth it? Why?
Thanks!
Jake Gulick, Black Rock, CT.
'73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]
Old 04-10-2005, 11:01 AM
Non Compos Mentis
How do you use the car? If you compete on R-compound tires, tha additional stiffness and lighter weight will make it worth it. For a street only car, probably not a big deal.
I had an '87 parts car- Engine, suspension, brakes, yada yada all went into my '73. Having an entire car made it a no-brainer for me.
Old 04-10-2005, 01:10 PM
I drive it as a weekend car and track it a few times a year. I have Kuhmo V700s that use for the track, and often on the street
I am concerned with all the bits that might be needed as much as the part itself...if the gains aren't there, is there a point? They sure would look pretty in a powder finished clear coat though!
Old 04-10-2005, 01:29 PM
drag racing the short bus
dd74's Avatar
I think you save about two or three pounds per arm. I think, also, you have to remove the engine for this. I'm not sure, but I'd look into it to see the value. Unless yours is a dedicated race car, I would think over the cost-to-performance ratio. If you do go this route, you might as well install rear monoballs.
The Terror of Tiny Town
Old 04-10-2005, 01:35 PM
I *Think* the bolts are facing the correct direction on the inside control arm pick up. I hope so, because monoballs on the arms are on the list!
One advantage to gatting new arms is the assembly cound be completely ready to go, and the process would be more of an R & R. Time savings in the long run.
Old 04-10-2005, 01:44 PM
dd74's Avatar
Well, Jake, like I said, I'm not entirely sure about the modification. My car already had al arms, so it was never on my list. I did consider the rear monoballs once, but my driving style and conditions, plus limited ability to make it to the track - in the grand scheme of things - made it economically unfeasible. They're great pieces, however, yet simply not necessary for me. If the monoballs can be popped onto the al. arms while out, yes, you're ahead of the game time-wise. My only concern would be if you need to drop the motor.
Old 04-10-2005, 01:53 PM
Plavan's Avatar
Do a search on Aluminum trailing arms... You should get some good info.
Chad Plavan
911ST Race Car/2.5L SS Race Motor #02
1972 911T- Numbers matching- Restoring to stock
2011 Porsche Spyder Wht/Blk/Carbon Fiber Buckets/6-Speed (Sold)
2016 Elan NP01 Prototype racecar- Chassis #20, #02
Old 04-10-2005, 01:54 PM
hey Jake.
cramer just posted a thread
Lime Rock Thrash: The Disassembly
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-10-2005, 03:06 PM
hey...thanks for the lonk. Looks like Cramer is having a good time! If my weekend were less hectic< i would have loved going out and giving him a hand.
So, it looks like a different brake line (2), and longer bolts are in order. (Assuming the eccentrics)
And bearings and seals are, I assume, one of those no brainers, right?
Old 04-10-2005, 07:40 PM
Licensed User
Shuie's Avatar
Ive heard that the weight savings is not a lot, but honestly, Im really surprised at how light my '74 trailing arms feel every time I have to move them around my garage. Maybe its becase they dont have rotors or calipers on them yet, but they cant weigh more than 15lbs each.
Old 04-10-2005, 08:30 PM
you can get wide answers to bearings R&R if their tight.
Grady posted, somewhat, that at 100k mi they have one foot in the grave and the other on a banana peel.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-10-2005, 08:36 PM
i want one of those...
Rufblackbird's Avatar
Location: formerly a grass shack in Hawaii, now Peoria, AZ
IIRC in '73 they had the dimples on the torsion tube, so your motor and trans does not need to come out. One thing for sure you DO need is the brake lines. I forgot and had to...um..modify mine to fit. As soon as I get a chance I'm gonna have to buy a new line and bend to fit.
Jeff
'72 911 T Targa widebody VTK #111385 http://www.911vtk.com
Old 04-11-2005, 12:44 AM
304065's Avatar
Jake,
All will be revealed: search under "Lime Rock Thrash."
Having done (half of) it once, it's not that difficult.
I would NOT do it unless you plan on racing or AXing.
Did the WEVO springplates become generally available yet?
'66 911 #304065 Irischgruen
‘96 993 Carrera 2 Polarsilber
'81 R65
Ex-'88 Carrera (Sold 3/29/02)
Old 04-11-2005, 03:51 AM
arrivederci's Avatar
Yep, brake lines are necessary. I bought a new line and bent it to fit. FWIW, the simple brake line benders you can buy at AutoZone, etc, won't bend a tight enough radius. I also bent a wire coat hanger to the shape that I was shooting for. You'll have to -um- improvise. It might've been easier to just buy the factory line (if you're using carrera or SC brakes).
I also went to monoballs at the same time. The trailing arm mounts on the chassis had pinched down over time, so I had to build a press to expand them a little in order to install the trailing arms. On my '72, the engine had to come out as well. Overall, on a scale of 1 to 10, its a 4 difficultly wise, but an 8 PITA wise.
- '72 911T
- '81 911SC Euro
Old 04-11-2005, 04:48 AM
randywebb's Avatar
you save 6 lbs. on one hand, that is approx. 1/2 as unsprung wt. otoh, it is only a 3% reduction in the total...
but, they are stiffer too.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 04-11-2005, 12:39 PM
OK, guys, thanks for the suggestions and good info, along with the educational links. I think I am going to go aluminum for a number of reasons.
1- It's a bolt on part, and a Porsche one at that. No decreased value, not that that is a major concern, but....did anybody see the orange T on E bay that was a no sale at 30K???
2- Aluminum is lighter, and doesn't rust...a more elegant material.
3- Better performance.
4- Exchangability. This is the major reason..I can gather the parts, and preassemble, and when everything is in order, it will be more of a R & R than a long thrash.
So, the final plan is alum arms with the WEVO SPS, the correct brake line as noted above, and Elephant monoballs on the inside. I'll cut the bolts per Dan Jacobs if needed.
Loose ends are: What material do I get them media blasted with, and is clear powder coating a good, or bad idea?
Old 04-11-2005, 09:08 PM
anything is gonna chip under there. I used the wrong clear that yellowed 50k mi ago on my trailing arms. I figured to just sand and dab later. Por-15 has a nice clear that's as hard as their other products but doesn't yellow as the rust preventive clear does. Por products are more like a resin than paint. I'll find the name of the nice Por clear if you want? I painted my new carbs with it.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-11-2005, 09:33 PM
YEa! If it doesn't have to go out and have a turn around time associated with it, and it saves money, it's all good!
Did you powder coat your trailing arms? Or use another type of clear?
Old 04-11-2005, 09:54 PM
I sand blasted the arms then used the wrong clear. No priming necessary for this type of job. I'm not pulling them for a redo until necessary. And I'm not motivated to sand while it's in there. The best clear I could currently find is Por-15 mfg called "Pelucid". It'll be relatively chip resistant under there. Any future chips require some 400 then a dab like every 25k mi of street use to be neurotically perfect. Otherwise faggetaboutit. A quick wipe and they clean right up. Before they yellowed I was sup-prised about all the nice comments on them.
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 04-11-2005, 10:09 PM
since they're not in the car yet just polish them
Jeff
Old 04-12-2005, 12:51 AM
