steviee7's Avatar
Send a message via AIM to steviee7
Question headlites/dashlights fade in/out
I've been noticing my headlights and dashlights dim to about 95% and then back to normal. It seems to change the faster my engine goes, It's really not too noticable but it is and I don't know what it is. It doesn't do it all the time, It could start out fine and then do it and then go away, it could start out fading and then get better. Sometimes while it's doing it I can open the sunroof and the you can hear the sunroof motor change sounds in/out. Could it be the alternator, I know it must be electrical but where do I begin.
I hate when it's electrical.
One time while it was doing it I turned on my rear window defrost and it stopped doing it. I thought ahhhaaa, I found it! but then it did it again, with or without the defrost button.
'86 911 Carrera coupe (silver) needs a lil' love
'90 VW Corrado G60 (yellow) close to death
'90 VW Passat wagon (white) a lot closer to death
'97 Chevy Astrovan (moms car) POS died!
'03 GMC Safari conversion van
Old 04-07-2005, 02:35 PM
randywebb's Avatar
may be Voltage reg
"A man with his priorities so far out of whack doesn't deserve such a fine automobile."
- Ferris Bueller's Day Off
Old 04-07-2005, 03:16 PM
19 years and 17k posts...
azasadny's Avatar
Alternator? Sure sounds like it to me...
Art Zasadny
Learning the bass guitar
www.ford.com
Old 04-07-2005, 03:21 PM
FrayAdjacent911's Avatar
Send a message via AIM to FrayAdjacent911
I'd say check your ground points... at the battery and engine/transmission. They could be pretty corroded.
Matt J.
69 911T Targa - "Stinky"
2001 Boxster "Stahlgewehr"
Old 04-07-2005, 03:23 PM
Brother's Avatar
I notice some similar behavior with my car. I have an aftermarket voltmeter on it as well and you can really see it happen. If I'm in a low idle with the lights on, they might dim. After about 1050 RPM, it is cured and the voltage will increase. I have an Optima which takes a little bit extra to recharge too. If it is low on charge, it will keep teh voltage at 12.5 until it comes back up to capacity at which time I'm seeing something north of 13V. I have never really gotten the 14V that most cars get. Don't know why.
Paul
1980 911SC Targa - Sold
1972 914 - Sold
Old 04-07-2005, 04:22 PM
350HP930's Avatar
If you have bad grounding or battery connections its possible to see the normal activity of the voltage regulator.
Old 04-07-2005, 04:35 PM
Senior Member
Had my lights all seem normal, then would go bright for a bit. Turns out that it was a voltage regulator going tits up, and the voltage going up to 16+ volts! Not good.
Get a digital volt meter and put in on the car while driving. See what the readouts are then let us know. Should tell a lot...
JoeA
Old 04-07-2005, 06:00 PM
I had that problem once but it went away when I changed the battery. How long since you last changed yours ?
Old 04-08-2005, 12:52 AM
randywebb's Avatar
I agree - do the cheapest thing first -- clean up the tranny gnd strap at both ends and its attchment points.
Next - do the easiest thing - ne battery or at least a thorough test at a battery shop (no where else). i.e. test under load.
Next will prob. be new voltage regulator....
Old 04-08-2005, 11:15 AM
