-   -   Help with starter problem (http://forums.pelicanparts.com/porsche-911-technical-forum/213734-help-starter-problem.html)
Oldspiker 03-30-2005 03:19 PM
Hi-
My car is a '76 911S that has been sitting in the garage since I got it in January. A few days ago I started it up and took it around the block and then while I was sitting in the driveway inadvertently (obviously, stupidly) momentarily turned the key in the start direction with the engine running. I then turned the engine off.
Since that time when I turn the key to the start position, there is no activity at the starter motor. I thought I'd ruined the starter so I removed it. When I took it to a shop they bench tested it and it worked just fine. I've reinstalled the starter.
I don't believe any current is getting to the starter. When I turn the key there is a click (a relay engaging?) and then a whirring sound that reminds me of the sound a windshield washer motor makes. This whirring sound continues until I release the key. I'm not sure where it's coming from.
Does anyone have any thoughts or suggestions?
Thanks a lot.
Bob
Jim Sims 03-30-2005 03:23 PM
Check the flexible ground strap from the body to the transmission (passenger side).
scottb 03-30-2005 03:34 PM
Do these starters have a solenoid? If so, is it possible the solenoid has gone belly-up?
Oldspiker 03-30-2005 03:39 PM
The starter does have a solenoid, but it tested out all right a the shop.
randywebb 03-30-2005 04:27 PM
The click is from the solenoid moving. The whirr means the starter itself is spinning after the solenoid clicks... I almost wrote engages, but it might not be engaging.
Jims idea is that you are not getting enough current due to corrosion. That is certainly the most likely situtation. After that strap start looking at other links in the chain such as the strap in the front corner of thetrunk, the starter switch, the battery condition, etc.
Oldspiker 03-30-2005 05:57 PM
I'm sure that the click and the whirr are not coming from the starter and solenoid. Before I reinstalled the starter, I turned the key to the start position and got the sounds I described coming from the front fuse box area.
I'm pretty certain the click is a relay, but I wasn't able to pinpoint the source of the whirring sound. There is a metal device about 1.5 x 1.0 x.75 in a rectangular bracket in front of and below the fuse box with 4 wires plugged into the bottom of it - one heavy guage red and on heavy guage black - that may be contributing to the sound.
The whole fuse box area and wiring is a mess-things have been hacked up and rerouted (maybe I should post some pictures). I've got work to do there, but until a couple of days ago the starter was working.
Bob
911pcars 03-30-2005 06:09 PM
Can you connect a voltmeter to the battery posts? During cranking, the voltage should drop from 12+ down to about 9+ volts. If the drop is below 9, the starter usually doesn't crank - check the battery state of charge (i.e. discharged or faulty battery).
Let us know.
Sherwood
Oldspiker 03-30-2005 07:36 PM
There is virtually no voltage drop when the key is turned to the cranking position – just the whirr and a drop from 11.9 to 11.7.
randywebb 03-30-2005 09:52 PM
OK that kind of a click.... The soenoid will make a bigger click...
So there is no click from the rear ---> almost certain that the solenoid is not moving. Likely due to resistance. So do the gnd strap first and report back. You may just want to get a new one. Be sure to clean up both areas where it mounts - you can use a dielectric grease on all contact surfaces.
The votage drop test is not real reliable - the problem is how much current can flow -- remember you can a nice voltage with current flow of micro-amps, but you can't move chunks of metal around with that much current.
911pcars 03-31-2005 12:34 AM
First of all, the battery should be fully charged. 11.9 is not. However, I don't think that's the crux of the problem.
The solenoid doesn't sound like it's energizing. A half-charged battery shouldn't have any problem energizing the solenoid. You should hear it click. However, getting the starter motor to rotate the engine is another matter.
"The voltage drop test is not real reliable - the problem is how much current can flow"
Current flow is a function of voltage and normal current flow during cranking lowers the available voltage. If the battery voltage drops only .2 volt, the starter motor isn't seeing any voltage and current flow is nil.
The following assumes the starter motor assembly was successfully bench-tested.
I suggest jacking up the RR and remove the tire. Check the connections on the solenoid and make sure they're on. I forget the correct color code but you can check with a voltmeter which wire is for the "crank" signal from the ignition switch (source voltage only available during cranking). You might discover:
a) the wire connector was not connected
b) the source wire or connector from the switch to energize the solenoid is faulty
c) the ignition switch is not connecting source voltage from battery to the solenoid wire
d) you may have switched the small wires on the solenoid.
Hope this helps,
Sherwood
Oldspiker 03-31-2005 05:07 AM
I will check the grounding strap later today, but my guess is that the problem is either:
"b) the source wire or connector from the switch to energize the solenoid is faulty
c) the ignition switch is not connecting source voltage from battery to the solenoid wire"
probably c).
My starter has only three wires attached to it, the two heavy guage wires from the battery and generator, and a smaller guage yellow wire which must be the connection that activates the solenoid. I was wondering if I were to jumper from the battery terminal on the starter to the this soleniod terminal, then if the starter turned it wold isolate the problem to the circuit between the switch and solenoid. Aside from grounding the battery, does anyone see any danger in this test?
rcecale 03-31-2005 05:14 AM
There is some great starter troubleshooting advice in this thread. Collectively, the guys here on PPBBS know everything!!! :D
Randy
Gunter 03-31-2005 09:37 AM
Oldspiker: Good way to go; get a 12V connection from the battery to the solenoid. (Small faston spade, remove yellow wire)) It should click (Engage) Be prepared that it will also spin the flywheel (Engine) So, take it out of gear. There will be a small spark when you touch the spade connector. Ensure good ground.
The solenoid is a switch devise that pushes the small starter gear into the flywheel ring gear. Only then will the starter spin to start the engine. It all happens pretty fast. The "thing" in the trunk could be an additional starter relay.
RoninLB 03-31-2005 01:11 PM
I use a screwdriver to jump from large starter terminal to solenoid.. make sure it's not in gear.
100-200amp battery draw will definately drop battery voltage significantly as per SL's advise.
911pcars 03-31-2005 01:16 PM
Large screwdriver works, but arc welding is a possibility for the careless.
Suggest a remote starter switch. Connect to terminals, then push button from a safe distance while sipping tea.
Sherwood
Wil Ferch 03-31-2005 02:03 PM
See here, too...even some embedded posts /pics
http://forums.pelicanparts.com/showthread.php?s=&threadid=186525&perpage=20&highl ight=wil%20starter&pagenumber=2
Wil
Oldspiker 03-31-2005 02:18 PM
Well, the starter passed the jumper test, so I it looks like the problem is in the circuit between the starter switch and the solenoid–the yellow wire.
I don't have a wiring schematic for my car, but is it safe to conclude that the diagram for the 911T that is posted at this (PP) web site is fairly close? If so, it appears that from the solenoid the wiring goes to a 14 terminal "multi-port connector," from there to a "buzzer," then to a 6 terminal "multi-port connector," and from there to the starter switch.
Having just started to work on this car I don't know where any of things are, except for the solenoid, of course. I'm guessing that the starter switch is behind the dashboard, but I have no idea where to look for the connectors and the buzzer.
I am appreciative of all your advice.
Bob
911pcars 03-31-2005 02:26 PM
Go directly to the ignition switch. The "start" or "crank" position often wears out. Remove the yellow wire from the existing ignition switch and connect it to
your remote starter switch (and a voltage source) to verify it's the switch and not an open in the wire.
Sherwood
crashmy911 03-31-2005 02:33 PM
make sure you are getting good connections and make sure the ground strap is clean. My car when it doesn't start is usually the ground strap. If your battery isn't good then start there. I thin it should be 12.5 or higher.
Tim Polzin 03-31-2005 02:47 PM
Re: Help with starter problem
Bob:
How hard did you turn the key? You may have sheared off part of the pot metal "key" that drives the electrical part of the switch. If it is original, it may have already been damaged.
If you had a spare electrical switch part of the ignition, you could quickly test it.
Tim
Oldspiker 03-31-2005 03:17 PM
From what I am reading it appears that the ignition switch may well have failed. However, I'd hate to go to the trouble of removing the switch just to find that it is all right. Where does the yellow wire coming off the ignition switch terminate? From the schematic it looks like it is at a 6 terminal connector. If I can find this terminal couldn't I check the voltage at this point when I turn the key?
Alternatively, can the wires be removed from the ignition swithch without removing the switch itself? This is unclear to me from the posts I've read.
Bob
911pcars 03-31-2005 04:39 PM
Bob,
This might be a case of the "reach around" to access, but not positive how to access your year ign. switch. The earlier models simply unscrewed from the panel. Yours is probably more involved with a steering wheel lock. Didn't the later switches come in two subassemblies (tumbler section vs. electrical section)?
Others may provide more info.
Sherwood
RoninLB 03-31-2005 04:45 PM
I'm laying in a bildge between two engines and all I have is a Huge screwdriver. It's a tight squeeze&maneuver.. but it could be done. Both engines have a common ground, battery bank is my pillow, and I'm wearing a 3oz silver bracelet.
flash zoom pow heat, and toasted hairs... "wow"
Kayser28 03-31-2005 04:52 PM
I had this exact problem on my 77', check to make sure the engine electrical harness is connected tightly right behind the 3 fuse box on the left rear of the engine compartment. Mine was a little loose and would to this intermittently. Very frustrating but a very easy fix. Good luck.
Mike
RoninLB 03-31-2005 04:57 PM
yep.. you may have a stock yellow wire connector Y laying behind your gauges that's 29yrs dirty? Opening up the trunk accesed wiring may be less work? That's also the area alarm nostart is usually connected. The cabin bulkhead plug feeds the trunk yellow wire.
RoninLB 03-31-2005 05:01 PM
yep.. that's the dirtiest and disturbed connector in the whole circuit before sol.
Oldspiker 04-01-2005 02:28 PM
"...make sure the engine electrical harness is connected tightly right behind the 3 fuse box on the left rear of the engine compartment."
Just to put this thread to bed, at least tempoarily. I traced the "yellow" solenoid wire to the connector mentioned above and removed the connector which was firmly seated. There was a bit of corrosion on some of the pins, I didn't take the time to clean it, but squirted a little WD40 on the connector and replaced.
Then I wedged myself under the steering wheel so I could look at the wiring coming from the ignition switch. I removed the three 6-pin (?) connectors from their sockets so I could see a little better and noticed that the connector farthest to my left (nearest the middle of the car) had the yellow wire coming from the ignition switch among the wires it was connecting. Then after looking around a bit more I plugged everything back in. Trying to come out from underneath the dash I momentarily thought I'd need the jaws of life, but once I was out (you guessed it) I put the key in the ignition turned it and the engine started immediately.
I don't think I've seen the last of this problem, but I've learned something–it's been interesting.
Thank you to everyone for all of your suggestions. I'm sure I'll be coming to you again. Now on to the brakes which barely work!
911pcars 04-01-2005 03:59 PM
Hooray. There is an alternative to replacing parts.
Sherwood
Gunter 04-02-2005 08:56 AM
Bob: Get yourself some dielectric grease (Or Vaseline in a pinch) and redo the multi-connector, ignition switch and any other connectors you can find. After so many years, corrosion is an issue with these cars, especially the fuse blocks. Electrical problems are a real PITA and I greased every terminal I could find.
WD-40 is just a cleaner and will evaporate; dielectric grease is permanent.
Also, consider the starter relay kit that mounts right next to the starter and will carry the load instead of the ignition switch. Go here:
http://www.pelicanparts.com/catalog/images/electrical/hot_start_kit.jpg
and:
http://www.pelicanparts.com/techarticles/mult_starter_diag/mult_starter_diag.htm
