Big black, especially in RSR guise is amazing Ted, would love to see it with those 15s mounted, I think there is one shot but you can't see them too well. Great work!
I'll post photos when that happens. :) |
Harvey is the best. He has some great stories too! |
Here's mine.......by my own hands......
Polished and Painted
I used the tech write up on how to refinish them.
It took about 4 hrs per wheel, but they turned out almost perfect. Very happy! Great job on the step by step write up on the forum. http://forums.pelicanparts.com/uploa...1265780792.jpg http://forums.pelicanparts.com/uploa...1265780864.jpg http://forums.pelicanparts.com/uploa...1265780945.jpg |
http://forums.pelicanparts.com/uploa...1265781324.jpg |
Home made media blasted satin coated track wheels.
http://forums.pelicanparts.com/uploa...1265808523.jpg http://forums.pelicanparts.com/uploa...1265808548.jpg http://forums.pelicanparts.com/uploa...1265808571.jpg |
On near all these fine refinnish job's Ive noticed that the stem metal support thingy has been removed. Is this common to do this? IF so, how complicated is it to remove? doesnt appear to be welded on to me. Planning to do mine soon and would like to know.
and if you don't replace them, you should get metal/stiff valve stems.
These do not bend and tear off at high speeds. I have flush mounted valve stems, looks a lot cleaner. |
Harvey Weidman's 15x14 with hand grooved Avon slicks from Roger Kraus. http://forums.pelicanparts.com/uploa...1265832360.jpg http://forums.pelicanparts.com/uploa...1265832398.jpg |
Thanks guys. Was looking at one yesterday and thought I Noticed what might be a very thin 3m type of tape. No way to do a proper polish with them there. Probably leave off and go back with lowest profile stem I can get, chrome covered at that.
are those stock fuchs wheel centers?
I'm amazed they are strong enough to carry that big of a wheel and tire, esp. on a race car. |
If you drive sanely on the street they should be fine with frequent inspections. According to Harvey... The 15x11 and 14s welded Fuchs were common on lower budget race teams in 74/75. In 74 the less funded RSR teams could not afford 917 rims and knock offs so they welded and widened their 9s and 11s into 11s and 14s. Then painted the barrels gray to match the anodized finish. http://forums.pelicanparts.com/uploa...1266083852.jpg |
Ted used to direct airplanes off and onto the ground, thus his preference for large tires. :)
Sherwood |
I went from a black and polished look to a Guards Red and dull look via the "scotch brite" method. Total cost less than $30.00 :)
Before http://forums.pelicanparts.com/uploa...1269638664.jpg After http://forums.pelicanparts.com/uploa...1269638754.jpg http://forums.pelicanparts.com/uploa...1269638786.jpg |
Tru Design 8 inch fronts and 9.5 rears
Glossy Black with polish hoops http://forums.pelicanparts.com/uploa...1269649710.jpg http://forums.pelicanparts.com/uploa...1269649790.jpg http://forums.pelicanparts.com/uploa...1269649814.jpg |
now it wants 917 wheels. ;) |
| All times are GMT -8. The time now is 01:09 PM. |
