Aiming Headlamps
Yes, I checked search.
There is a procedure provided by Stern in our archives.
Question - Is there an easier way to aim new headlamps?
I have my new Projector beams ready to go, except they are not aimed correctly at all.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 01-10-2012, 12:11 PM
Spiderman
Jesse16's Avatar
Easier than drive up to a wall at night and adjust ?? I just used a tape measure on a blank wall down at my local shopping mall out back. For straightness, just stand behind car and eyeball that one. Then when driving, confirm that all seems good. D. Sterns instructions are a bit long winded but have the same effect.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 01-10-2012, 12:50 PM
Brandon-FL's Avatar
There is an easier way...do all your driving at night and when people quit flipping you off and flashing their highbeams at you, you'll know that you have them adjusted correctly.
Brandon
"Life is hard; it's harder when you're stupid." - John Wayne
Old 01-10-2012, 01:13 PM
80-911SC's Avatar
I usually pull in about 10-15 feet from the garage door .. then measure to the center of the lights on the car .. put a tape line on the door or just line up with a panel crease or a line on the roll up door that is close to the height .. on the low beam center at that height and point the beam about a foot off from straight to the right side ..
It may not be the perfect way but its close .. they have alignment levels that you can buy that have two levels in them and suction or hang on the light ...or you could go to a shop that does brake and light inspections and for a small fee they will adjust your lights ..
Old 01-10-2012, 01:38 PM
an idea, with one on at a time, at night see where each lands using low beam and high beam, I think each side has a different "shutter" outline, on the left light, the light going left is cut off a bit more
Old 01-10-2012, 01:39 PM
here are some good instructions. http://www.coolbulbs.com/HID-VISUAL-HEADLIGHT-AIMING-PROCEDURE.pdf
I was able to shortcut a bit by first driving up to the wall (bumper on the wall) and marking the centerpoint of my headlights onto the wall and then backing straight back to rough in the alighment.
Old 01-10-2012, 01:52 PM
Thanks guys! Looks like I'll be aiming some headlamps this weekend.
Old 01-11-2012, 07:30 AM
Originally Posted by Darrin
I was able to shortcut a bit by first driving up to the wall (bumper on the wall) and marking the centerpoint of my headlights onto the wall and then backing straight back to rough in the alignment.
I have been doing this for years using an office building around the back. Blue painters tape for marking the wall and a tape measure. It takes longer to figure out which way to turn the screws for the desired movement than actually dialing them in. The early drivers handbooks had instruction and a diagram for the procedure including how far to back-up.
Free will is doing what we must joyfully.
Jung
'68 912 Coupe
'82 SC sunroof
Old 01-11-2012, 08:38 AM
