Black Vinyl Dye
I have some white spots on my dash that won't come out and I want to get some black vinyl dye to cover them. Does anyone have a recommendation on where to get vinyl dye?
PorschePilot 74 911S Targa - High Quality 2.7 Rebuild and Full Body Restoration MID9 Member Beechcraft V-Tail Bonanza (Fly'n high and low) |
The best black dye is from VHT, Penetrating Color Dye ,Satin Black, Number 18.04 (14 Euro in Holland). See picture for the Chrome variant(very good for internal reflector side of rear taillights by the way). Satin Black can also be used on black weather striping after a thorough cleaning. I have used this on the exterior striping on my Volvo 240( The Flying Brick), which was faded grey, now afters 4 years still deep black, no other treatment needed. Before I had tried some 6 other products, with dissapointing results. Before spraying, make sure the ambient temperature is 30 degrees Celcius, for example with a warming lightbulb.On the dash, you may want to apply it with a small brush. Good luck,
Jan
Um, I don't think I would be using that stuff to "rattle can" my dash!
![]() If you are looking for excellent interior leather/vinyl dye, start here: www.leatherique.com You can either order the exact color code, or you can send them a swatch, and they can match your color exactly, even taking "sun fade" into account. |
Marks-A-Lot? KIDDING!
There was a really good thread recently by a Pelican that dyed his seats. You might try to find it for ideas on how to dye the dash.
1984 Targa |
Eric, indeed not spraying, but applying otherwise, as I described.
Letherique is also an option off course. It fades sooner on such an sun-exposed area imo. Black is easy to work with, so no sampling of the dash is required. Jan |
So does VHT make a product called Penetrating Color Dye ?
Make Bruins Great Again
I don't think you can technically "dye" Vinyl. It isn't porous so all you are doing is painting the surface area. You can dye leather because it gets down into the pores of the leather.
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
I just ordered VHT Penetrating Dye in black satin from Summit Racing for $7.85 a can. If it works well, it is a cheap fix.
Wayne, would you considering stocking it?
Me like track days
Surflex. The best -
Used it on my headliner and side panels. Looks perfect after 5 years.
- Craig 3.4L, SC heads, 964 cams, B&B headers, K27 HF ZC turbo, Ruf IC. WUR & RPM switch, IA fuel head, Zork, G50/50 5 speed. 438 RWHP / 413 RWTQ - "930 is the wild slut you sleep with who tries to kill you every time you "get it on" - Quote by Gabe Movie: 930 on the dyno |
Surflex says it for leather, have you tried it on vinyl?
Me like track days
It is also for vinyl - mine is - it works A1
Ayo Irpin, Ukraine!
Harmlessly passing gas in the grassland away; Only dimly aware of a certain smell in the air |
Me like track days
Over a white.
The stuff ranks right up there in quality with WEVO and ELephant products........the best.
