-   -   part # lower temp fan sensor 964? (http://forums.pelicanparts.com/porsche-911-technical-forum/213835-part-lower-temp-fan-sensor-964-a.html)
TRE Cup 03-31-2005 10:08 AM
Searched the forums but could not find it: there is a lower temp sensor that some have screwed into the oil cooler so the fan is actuated at lower temp (210-214 F) does anyone know the part number?
Thanks in advance!
db
Wil Ferch 03-31-2005 01:27 PM
964.624.110.00
Opens at 100-110C ( approx 212F +/-)
Uses same 14 x 18 mm sealing ring
"Standard" unit opens at 244F ( 118C).
- - Wil
TRE Cup 03-31-2005 02:51 PM
terrific - thank you! -oops- that part number is for the stock unit as listed in pet 5
Tigerrat 03-31-2005 09:06 PM
db - The one I used was actually for a BMW IIRC. Got it from Pelican, their #61-31-1-364-273. I'd swear it was in their catalog next to the stock one but I don't see it there now. You'll need to splice a wire or two I recall. Correct, 99C. Ken
Wil Ferch 04-01-2005 07:23 AM
Let me be clear...yes..that part number is stock for 964 but is "not-stock" for the 3.2 application.
The stock unit for 3.2 opens at a high 244 degF....the 964 closer to 212..
- Wil
TRE Cup 04-01-2005 08:23 AM
ok- thanks guys!
db
