-   -   Installing O2 Bung (http://forums.pelicanparts.com/porsche-911-technical-forum/213864-installing-o2-bung.html)
pryord 03-31-2005 12:30 PM
Installing O2 Bung
I need to install an O2 bung on an older Euro Premuffler. Any tips? Can I just take it to a muffler shop and have them weld one in? ..or can I just drill a hole and weld a bolt of the same diameter as the O2 sensor?
RickM 03-31-2005 12:34 PM
Re: Installing O2 Bung
Originally posted by pryord
or can I just drill a hole and weld a <b>bolt</b> of the same diameter as the O2 sensor?
You mean a nut?
Jim Sims 03-31-2005 12:40 PM
Don't O2 sensors use a sparkplug thread; is this a common nut size?
RoninLB 03-31-2005 01:00 PM
SSI sold me an O2 bung. I don't know who else sells them. It is spark plug thread.
jpnovak 03-31-2005 01:13 PM
Any auto supply should sell them. Jeg's, summit, etc. They are less than $10 and get welded in. Check a local exhaust shop. they will probably have them as well and could easily install it.
Wil Ferch 03-31-2005 01:14 PM
Got mine from Jerry Woods...also $10 or so...
18mm x 1.5
Wil
