87 Carrera Suspension Mods
Had car for 3 years now and time for some upgrades/mods. Engine going with your chip, intake and exhaust
What should I do to the suspension and how much should I be prepare to spend ?
87 Carrera Coupe 03 Infinity QX4 |
What do you do with the car? Mostly spirited street driving, occasional weekend and lots of track, or is it your daily driver?? That will affect what you want to do.
Is the thing stock? Are the shocks and bushing old? More details and you'll get better info. You could also do a search since this sort of thing has come up 100 times before.
Hey Mas,
Thanks for the "more details, better info". At this time 100% street driving. Yea, all stock and old. I see you are in Houston. Ever go by RPM ?
MBruns for President
Go here - click on the yellow dots...
http://www.elephantracing.com/suspension/diagram/911suspensiondiagram.htm I think that's all you'll need to know about 911 suspension upgrades...
Current Whip: - 2003 996 Twin Turbo - 39K miles - Lapis Blue/Grey Past: 1974 IROC (3.6) , 1987 Cabriolet (3.4) , 1990 C2 Targa, 1989 S2 |
Will program for food
I am in the middle of upgrading my suspension, front and rear.
My car will be street auto-x and maybe more. I have completely removed both front and rear suspension and am close to reinstalling. I went with New bilstein sport shocks- front and rear 21mm front torsion bars (old are 19mm) 28mm rear torsion bars (old are 25 mm) Elephant racing poly bronze bushings front and rear (I do not want to ever, ever replace the rear torsion plate rubber bushings again. That was a pain) New rubber bushings for sway bars bump stear kit turbo tie rods new wheel bearing front and rear, etc... I know I am forgetting something, but that is all I can remember for now. Price - I dont even want to know, but if you ask real nice I will look up how much I have spent
Greg Hnat 87 Targa Disassembled 90 944 S2 Auto-x, DE and semi-daily driver 98 Jeep Cherokee |
I'm told that the Elephant items are too harsh for 100% street driving by people who have used them....
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off |
I guees I will find out soon enough.
Why would anyone mod. an '87 Carrera?
2022 BMW 530i 2021 MB GLA250 2020 BMW R1250GS |
Friend of Warren
Kurt V No more Porsches, but a revolving number of motorcycles. |
Here is the text:
We have installed a couple sets of the Elephant Racing poly-bronze bushings on track only cars, and although they worked well for that application I would not want to have that harsh of a set up for a street use car. I will give them credit for at least providing for a way to grease the inner bushing of the spring plate, not able to be done with all the plastic bushing replacements. We always installed grease zerks, and grooved the inside of the bushing for greasing maintenance on the ones where you could get access, but that inner spring plate was impossible. There is no question that I would prefer, and have used, the Neatrix bushings in the rear for the street, but the fronts are the problem since Dwight hasn’t yet made the Neatrix bushings for those arms. At least the front bushings are accessible to install grease zerks. Given all that, If I had to replace the front bushings, even for street use, I think I would use the Elephant racing bushings, at least their bronze ones won’t wear out like the plastic ones did. This was from Ed Mayo, the PCA technical person. So, FWIW, that is his recommendation (note the F vs. R difference) and his basis for the assertion. I'll be very interested to hear from those who have experience doing this on a 100% street car.
"A man with his priorities so far out of whack doesn't deserve such a fine automobile." - Ferris Bueller's Day Off Last edited by randywebb; 04-01-2005 at 01:00 PM.. |
I still find the original question odd....
There is no real "purpose" ...or design-shrift for what the goal at the end of road is supposed to be. Porsche had to compromise for all manner of possible uses..and they did a fine job for that. For someone to say "I'll be driving primarily on the street" and says nothing else...does not give us anything to go on. Stiffer springs, shocks with more control , bushings, etc...are meaningless if there is no "target". RUF's Yellowbird of '87 uses 19 mm front and 25 mm rear torsion bars. Pretty much stock. And goes 211 mph.....with apparent stability as quoted by a R&T test. RUF's philosophy is that you need suppleness in the suspension for it to "work". A track car...OTOH....needs things stiffened up so that transients and such can be handled better, etc. Here's a suggestion. Street driving? Freshen up and replace all the wear points...new tie-rods, ball joints, etc. Not as "sexy" as saying you bought Polybronze bushings, etc...but it'll get the job done. Maybe go for a slight lowering to Euro spec....do a "fine cut" on alignment specs and if shocks need replacing, go for a good set of Koni's or Bilsteins. Wil
Wil Ferch 85 Carrera ( gone, but not forgotten ) |
Though I don't know the details of the cars Ed Mayo prepared, he describes them as Track-Only cars. I will assume that they have stiff springs and stiff shocks and perhaps low-profile tires. I have no reason to doubt his observation of harsh ride quality.
I will differ with his conclusion that the harshness is the result of the Polybronze. In fact the stiff bars and shocks will ride harsh with any bushing, including factory rubber. Combined with streetable shocks and torsion bars, Polybronze rides very smoothly. That is an observation shared by many Polybronze users on this board.
Chuck Moreland - elephantracing.com - vonnen.com |
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar. '11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX. |
It is my understanding that the polybronze tidbits, allow PRECISE freedom of movement, thus allowing the suspension to do its job. If this is the case, its certainly NOT the polybronze that makes the suspension stiff.
If anything, this would make the suspension more plyable, with much better response to subtle suspension and tire pressure changes. I dont know about some of you guys, but I would find that preferable in ANY vehicle I ride or drive. Lets see...More precision, less friction........ I'LL TAKE IT!
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) Last edited by Nine9six; 04-01-2005 at 03:05 PM.. |
fancytown
PM Pelican username "einreb". He just did a lot of work on his '88, and went thru a lot of options with a lot of people.
all cars sold. |
Replaced all the bushings in my 89 with elephant products and I am very happy with the results. My car is street driven only. If you are going to do it, you might as well do it right. As you will notice a few of these so called EXPERTS on this site are FOS
Dude, I'm kidding. I did every mod. imagineable to my '87 Carrera.
drag racing the short bus
The Terror of Tiny Town |
True, getting them lighter helps. But generally, what weight you save is often equaled to what safety measures you add, (roll cage/bar). It depends on what extremes you choose to take and the condition of your car. My car is in perfect shape and I would have a hard time gutting it to save weight. I added 22/31 torsion bars, custom valved Bilsteins, removed any trace of rubber in the suspension and replaced with polyurethane, front monoballs and strut, adjustable rear spring plates, 27 front, 30 rear SmartRacing bars, lowered it as far as possible. After using this setup, especially at the track, my car is much more where I like it. Maybe too extreme for most street driving, though. We did the same to my brothers 87 but also stripped it and got the weight down to 2400lbs. Now that car flies.
