Identify this Engine please
I purchased '70 911 with what I was told is a rebuild 3.0L SC motor from a different car. It has updated tensioners, carrera valve covers and supposedly higher compresson 10:1 pistons.
But I'm a little confused as to the serial numbers on this engine. It doesn't match my other SC engine. The vertical number on the side of the fan is: *67C0298* The horizontal number is: 930/60 I have this engine up for sale. But if it turns out to be something special I may just rebuild it. Low compression in cylinder 2. Can anyone enlighten me? |
A 930/60 is a RoW 3.3 Turbo, 97 x 74.4 = 3299 cc.
I think the "C" may be a zero. If so; 670xxxx 6 = Six cylinders. 7 = Turbo 3.3 RoW/Japan. 0 = 1980 xxxx = Consecutive serial number. If so, that would make it an '80. If it has the 74.4 mm stroke crank, you could add some 100 mm P&Cs and have a high compression 3.5. Worth looking into. Best, Grady |
According to the Red book it is 1981 turbo engine for RoW/Canada.
I have made sure. There is definitely a "C" in the number not a zero.
*67C0298* But the engine is an NA. Did someone build a NA engine out a turbo case? |
I went here;
http://www.adelgigs.com/911scproductiondata.shtml And the “C” appears to indicate a 1982 model year engine. That now leans toward an ’82 3.3 Turbo 930/60. Yes, you can build a NA engine on that base. Best, Grady |
Thanks guys,
looks like its a 930 turbo motor from a 82. Here is a link I found with all model year codes: http://home.arcor.de/s-g-e/911dat.htm I don't want to open up the case to see what's in it until I'm sure if I want to rebuilt it. But it has been converted to NA. My next question would be what would this motor be worth after a rebuild or in its present condition? Currently cylinder two is dead. I may pull the head and check to see if it's a valve. All other cylinders have good conpression. |
I would recommend an additional cylinder leak test. That will give you an indication of where a problem is. You can do this even if the engine is out of the car.
Best, Grady |
I have decided to go ahead with the sale. The engine is in the classified section.
Engine for Sale AD thanks |
| All times are GMT -8. The time now is 08:27 PM. |
