-   -   Help! Need sizing of threaded CIS fitting on later gas tank (http://forums.pelicanparts.com/porsche-911-technical-forum/214498-help-need-sizing-threaded-cis-fitting-later-gas-tank.html)
rennch 04-04-2005 01:01 PM
HI...I need to get an adapter for my new fuel tank, which I think came out of a 79. It's got a threaded connection where the hi pressure CIS stuff connected to it. I'm at the office at the moment, and don't have access to a service manual. Does anyone know the size of that threaded connector on the gas tank?
Thanks!
jpnovak 04-04-2005 01:08 PM
78 tank to a 71 car. this adapted the tank to the tunnel. I still have a rear mounted fuel pump.
http://forums.pelicanparts.com/showthread.php?s=&threadid=168660&highlight=fuel+t ank
rennch 04-04-2005 01:14 PM
Ok...so I'm clear...
You ran your SUPPLY side off the drivers side, bent fitting, and the RETURN side to the 14mm X 1.5 (Thanks for the size...) side?
jpnovak 04-04-2005 01:52 PM
HMM I don't remember which goes where. The adapter allowed me to hook both up to the tunnel. Our of the tunnel I have two lines. One is supply to my fuel pump and the other is return. I think the larger diameter is the return.
rennch 04-04-2005 01:54 PM
I think I'm set, using those settings you had from the previous thread. Thanks for the help.
scottb 04-04-2005 04:14 PM
emptyo: you have mail.
