-   -   FRont Susp Pan - fix or need replaced ? (http://forums.pelicanparts.com/porsche-911-technical-forum/214881-front-susp-pan-fix-need-replaced.html)
ecm911 04-06-2005 11:53 AM
Hello,
I have a 78 911SC that has rust on the front suspension pan. Looking for some guidance. The question - Can it be repaired or does it need to be replaced.
Suspension points are solid - rust not even close.
The rust on the bottom in the center section for about 8-10 inches. In fact I removed the metal from the area to get a look inside. It certainly seems to me that this was the extent of the rust. Rest is very solid.
So I can treat this area for rust and weld a piece on the front or does it have to be replaced ? It goes without saying I would rather fix than replace, but I would also love to same some $$.
I do not have a picture of the current condition on the car, I can get that later - if helpful. But I have indicated on the picture of an uninstalled piece where the rust is- in the red box.
Thoughts,
Thanks , Earl
http://forums.pelicanparts.com/uploa...1112813522.jpg
Jerome Ryals 04-06-2005 12:01 PM
IF you are positive thats the extent of the rust you should be safe to fab a piece and repair, need to see if you can find out why that was where the only rust turned up though, hood seals leaking, etc.
ecm911 04-06-2005 03:54 PM
Jerome,
Thanks for the reply. I made a mistake on the picture - the rusted area is NOT where I indicated in the first pic. I have attached a corrected picture - the Yellow area is where the rusted area is.
Does you opinion chnaged?
Sorry for the confusion.
Earlhttp://forums.pelicanparts.com/uploa...1112828083.jpg
johnsjmc 04-06-2005 03:57 PM
I agree it would be easy to repair the area indicated .Clean up with a disc grinder before MIG welding in a patch will confirm the extent of the rust. The usual failure spot is the crossmember between the 2 front lower A arm mounts not where you have indicated. Poke around with a screwdriver to see if any weakness is in the crossmember. If originality is a concern consider the front section replacement anyway.
ecm911 04-06-2005 04:09 PM
Johnsjmc,
Thanks for the post Just want to make sure you saw the revised pic. I think the rust is where you indicated - between the a-arm mounts.
Earl
johnsjmc 04-06-2005 04:19 PM
I just saw your revised pic and you have rust where I expected it to be. If the top of the crossmember is sound you can still repair it without full replacement.
ecm911 04-06-2005 04:25 PM
Thanks,
In my opinion the top of the crossmemeber is sound, but I intend to really get at it with the grinded and make sure.
Thanks again, Earl
