Tower strut brace ?
Good morning
I just installed a tower strut brace on my 911, and I was wondering how much tension I should put on it with out setting the alignment off? Thanks Dan |
If someone replied on how much measurable "tension" to apply, would you be able to measure it?
I would suggest simply snugging the brace to your struts existing settings.
If it flows, it goes. If its smooth, it moves. Any questions? 96 993 C2 (Current) 87 911 Factory Turbo-Look Cab (Sold) 85 911 Factory Turbo-Look Targa (Gone) |
Somatic Negative Optimist
Dan: No pre-load on the strut brace; just neutral.
Can you post pix of the brace and how you attached it?
1980 Carrerarized SC with SS 3.2, LSD & Extras. SOLD! 1995 seafoam-green 993 C2, LSD, Sport seats. ![]() Abstract Darwin Ipso Facto: "Life is evolutionary random and has no meaning as evidenced by 7 Billion paranoid talking monkeys with super-inflated egos and matching vanity worshipping illusionary Gods and Saviors ".
Original Owner
Here we go again.......
tsuter 78 911SC Turbo Targa Thaaaats Right!! |
Thanks for the reply's. I installed it with information from the project 101,but there were no info on the tension. Thank you
Dan |
Funny you should mention this, I just installed the Elephant brace this morning. I can't believe how easy it was! I don't know why, but I thought it would be harder. 15 minutes max.
In THOSE instructions, it says to set the bar at neutral, then create tension by turning the bar 1/3 of a turn. I can't speak for other brands...... -Chris
1987 Guards Red Targa (sold) 2006 Toyota Tundra DC 4x4, the "man-e-van" 1998 CR500 Well on the fringe...... |
