targa bar vinyl?
When I compare this picture of the Pelican part and my own Targa bar liner....I worry that the vinyl is suppossed to be two parts.
My largehorizontal vinyl is fine.... It is the vertical edge that runs closest to the side windows, right beside the targa rubber seal that has cracked./ripped and needs replacing. Can someone confirm if the Pelican kit will fix that area as well? Targa Bar Vinyl, 911 (1974-89) A-565-511-40 $35.70 |
I just replaced mine. I am not sure which one the part # is referring to as I got mine from another well know interior vendor, but it is two separate parts. I would call Pelican to confirm that you are ordering the right part.
You do realize that in order to replace the vinyl, you will also have to replace the targa seal?
Neil '73 911S targa |
who was the interior vendor?
