AC delete "lite"
I've got to believe that my AC has long since drained. I don't think its worked in years.
81'SC If I want a short 2 hour job underdeck lid clean up, can I just remove the condensor and the finned radiator under my decklid along with the visible hoses? Any other words of advice? |
The condensor is the finned radiator on your rear deck. You must mean the compressor....You should be able to easily remove both in a couple hours if you have the proper tools
I had the same thing done with mine. I didn't cut any of the hoses I just tied them together and they sit at the back of engine compartment out of the way.
| All times are GMT -8. The time now is 02:44 PM. |
