Typical Fish's Avatar
HELP! '84 3.2 Carrera DEAD!
Here is the scenario; any help would be much appreciated as my car is currently locked in the back of a warehouse...
I have been having a problem with the engine "stuttering" at low speeds, it feels almost like the fuel and/or spark are completely interrupted for a second or two... It will happen once or twice, then the car will run fine... Sometimes it goes a day or two without it happening... It has gotten slowly worse (despite my best efforts; filter, plugs, etc) and on Friday the car stalled on me in traffic and would not start... The weird thing about it is that it then fired up and ran fine for about a block before it did it again, then repeated... As I said, now it's in it's "wont start" mood... Any thoughts?
Thanks in advance.
Matt
Matt
Old 04-10-2005, 09:31 PM
Check the DME relay under the drivers seat.
I had a similar problem that turned out to be a loose connection where the fuel pump wire went into the fuse box.
Good Luck.
'69 911 Targa w/ 3.2
Old 04-10-2005, 10:00 PM
ricwon's Avatar
Send a message via Yahoo to ricwon
I had the same type of problems on my 86 a couple of years ago. I replaced the dme relay, fuel filter, and had my dme circuit board reflowed. It turned out to be the head temp sensor. No more problems. Ric
86 911 carrera targa
83 911 sc targa, totalled
01.21.13 end of an error.
Old 04-10-2005, 10:12 PM
JTL JTL is offline
JTL's Avatar
Does the fuel pump run when you try to start? Does the engine crank? Could also be a bad flywheel reference sensor.
jt
Old 04-11-2005, 04:02 AM
If not DME relay....maybe one or both of the speed reference and crank sensors ( both near the flywheel)...
Wil
Wil Ferch
85 Carrera ( gone, but not forgotten )
Old 04-11-2005, 05:44 AM
IROC's Avatar
DME relay is a quick place to look first. After that, the Bentley manual has a pretty good diagnostic section on the DME system and most things (with the exception of the speed and reference sensors) can be checked with a multimeter. Sure beats replacing good parts.
I wouldn't suspect the reference sensor as I *think* the reference sensor is only used to allow the DME to find TDC during starting. Once the engine starts, I don't think that the reference input is used. I might be wrong on this, though.
Mike
Mike
1976 Euro 911
3.2 w/10.3 compression & SSIs
22/29 torsions, 22/22 adjustable sways, Carrera brakes
Old 04-11-2005, 06:48 AM
